Latest: DanDan17
Overall: 17128
Online Now [67]:
Visitors: 66
Today: 17353
Total: 100578041
Forums › The Car › 206 Talk › New Car, Purchased today, minor problems, please help :)
maximus.darby
PostPosted: Thu Nov 25, 2010 6:12 pm Up
Hi All
i purchased a 206 quiksilver, 1.4, 51 reg today, and i'm loving it, however there are a few niggly bits that are bugging me, and i'd like some advice on how to correct them.
First of all, the clock doesnt display, i believe it needs new bulbs, which bulbs do i get? and is it an easy job to fix myself?
2nd problem - the bolt has come off the mechanism you use to fold the seat in order to let passengers in on the drivers seat, so the handle just falls off.....are these generic bolts, where could I acquire one?
lastly, and this is the biggie, i've noticed a small dent in the driver side door that has slightly made the join on the door raise a little, (enough to make it look like the door hasnt been shut properly) is there a way I can bend this back, or will i need to look at buying a new door entirely??
sorry for the vague descriptions, it's late, i've been bombing it around all day haha..
many thanks for any advice in advance
Max Darby
Peugeot 206 Quiksilver, 1.4, 51 Reg, 34,000 Miles
EDP407
PostPosted: Thu Nov 25, 2010 6:14 pm Up
god help you. I went through 4 displays trying to make it work :L best of luck
Mk1 Seat Leon Driver - Once a proud 206 driver!
Ali_H
PostPosted: Thu Nov 25, 2010 6:22 pm Up
Bulbs are about 90p each from Pug, as are the bolts.
A pic will help for the last question.
kurtis wrote:
maximus.darby
PostPosted: Thu Nov 25, 2010 6:33 pm Up
Will add photos tomorrow, too late and dark now!
Max Darby
PostPosted: Thu Nov 25, 2010 11:53 pm Up
Yes the bulbs are easily enough to do yourself, there are guides on here how to do it and like someone has said above you can get them cheap from the peugeoit dealership
If you take a pic today of where the bolt your needing is, im sure i have some which i can send over
Good man Very Happy
vipertsniper
PostPosted: Fri Nov 26, 2010 12:56 am Up
got my bolts from an independent wreckers, got 4 for free but had to get them myself (which was really cool)- had gone to motorhog first they wanted £5 for 1 bolt.
am without car Sad
PostPosted: Fri Nov 26, 2010 1:06 am Up
Motorhog is a rip off!!
there's 2 yards near there which i always use and they are cheap as a £5 lapdance
Give me a shout anyway mate if you want 1 or 2
Ernie
PostPosted: Fri Nov 26, 2010 1:26 am Up
bulbs are a 5 min job to fix as is the bolt on the seat.
Just pop to your local breakers and learn how to take apart then repeat on your own car.
As for the door cant help until a pic is up.
Welcome to the site..
\"It just went bang\"
Logan
PostPosted: Fri Nov 26, 2010 3:35 am Up
The bulbs are available in Halfords to! Be sure to change ALL the bulbs in the unit (blown or not) otherwise when you get it back together you'll find the ones you didn't change have blown....
Bin there done that!!
st3v3n
PostPosted: Fri Nov 26, 2010 5:02 am Up
Not always the bulbs that blow. They suffer from fatigue on the circuit board and the solder comes away. If the bulbs don't sort it crack it open and you will see the damage. easy to fix with a soldering iron and small length of wire.
ICE goes in drinks. NOT in cars.
Will180
PostPosted: Fri Nov 26, 2010 7:54 am Up
how strange. i have the exact 3 same problems display bulb hand on passenger seat and dent in driver side door just above the window (result of sum little sh*t putting my window thru 2 weeks ago) which im planning to sort all this weekend :/
04/07/10. Black 206 XS 1.6 - Sold
29/03/11. Black GTI 180, Full Sp Kit
maximus.darby
PostPosted: Fri Nov 26, 2010 7:57 am Up
that is strange!
how are you going about fixing the door may I ask?
I've tried uploading photos to help explain my issue, but i'm at work atm, and even though i work in the IT department, even I can't stop the upload filter kicking in Wink
Max Darby
