Online Now [1045]:
Visitors: 1045
Today: 57777
Total: 143255942
Forums › The Car › 206 Talk › How do you turn off 'auto lights' on an 03 HDI
hlhks1
PostPosted: Fri Nov 26, 2010 4:55 pm Up
what do you do as putting too much strain on the batter/struggling these cold morninhg?
thanks
blah blah blah
kieron
PostPosted: Fri Nov 26, 2010 4:57 pm Up
hold in the button on the light stalk when the ignition is on it will say deactivated or activated
Account suspended
PostPosted: Fri Nov 26, 2010 4:58 pm Up
You will also hear a bong as well.
Better bet instead of turning them off, get yourself a better battery
PostPosted: Fri Nov 26, 2010 5:07 pm Up
I need a new battery for this winter, no idea what i'm buying though the last one i bought was crap Sad
PostPosted: Fri Nov 26, 2010 5:09 pm Up
Look at getting a Varta one Jord
PostPosted: Fri Nov 26, 2010 5:12 pm Up
They the best one's then? Just had a quick browse through the website and there seems to be lots of different sorts what should i be looking at mikey?
DeadEyePaul
PostPosted: Fri Nov 26, 2010 5:15 pm Up
Been told if your car is petrol it's better using the battery from a diseal as they retain more charge.
This advice was given to me from a car audio expert when I asked about dimming headlights from the subwoofer pounding notes
PostPosted: Fri Nov 26, 2010 5:16 pm Up
Yeah Varta are one of the best ones, if you are running a nice audio set up I would go for one that is for your car but go for the heavy duty one and you will be fine.
Dillon
PostPosted: Fri Nov 26, 2010 5:23 pm Up
Staff - Dillon
When my batteries have died I have always replaced with the diesel version they last longer with a basic audio set up.
PostPosted: Fri Nov 26, 2010 5:45 pm Up
get an optima battery used to use these in my old range rover split charged to power the winch,bonnet lamp pod, sound system, cb radio etc and never had a problem they are top dollar to buy but you get what you pay for
namgaj
PostPosted: Fri Nov 26, 2010 7:11 pm Up
Look here for your batteries, I got an Exide one for the jag, as they go through batteries every two years!!! www.tayna.co.uk/fitmen...Guide.html
4.0 V8 S-Type Jaguar
