Online Now [690]:
Visitors: 689
Today: 99288
Total: 150953901
Forums › The Car › 206 Talk › couple of questions.
Forum Index › 206 Talk
swfcdan
PostPosted: Sat Nov 27, 2010 10:38 am Up
Hi all, recent got a 206Gti V reg and everything is a ok, but i just have a couple of questions.
I was thinking of draining and replacing the coolant fluid. Is there a particular type that i could get from halfords that i need to put in?
Also, the digital temperature control display does not work, is this an easy fix?
Newbie owner
PostPosted: Sat Nov 27, 2010 10:40 am Up
any engine coolant will do. basically they are just water+antifreezer+anti-rust chemical
PostPosted: Sat Nov 27, 2010 11:42 am Up
Regarding the clock, it will most likely be a ppt30 display and one of the solders has most likely broke. There's a guide on how to repair it here.
206info.co.uk/Forums/v...t=206.html
PostPosted: Sat Nov 27, 2010 12:18 pm Up
I've just changed my coolant and I've used the blue stuff which apparently lasts for 2 years. I think the red OAT stuff can be used which is supposed to last 5 years. The coolant system just need a thorough flushing first.
