Latest: lio94
Overall: 17181
Online Now [147]:
Visitors: 146
Today: 41310
Total: 141124676
Forums › The Car › 206 Talk › How much to reset airbags module
roscoe
PostPosted: Mon Nov 29, 2010 1:18 pm Up
Does anyone know much this costs as both my airbags have deployed. I can get hold of the parts 2 x seat belts, 2 airbags and the modulator.
Just not sure how much pug dealership will charge. Or any other garage that can do it.
Used to own the 206 pictured above
M sport BMW E90 - Gone Sad
Now own Audi A5 Sline Smile
PostPosted: Mon Nov 29, 2010 1:22 pm Up
Rolling Eyes
roscoe
PostPosted: Mon Nov 29, 2010 1:24 pm Up
I can get the parts no problem. Sure I don't need it resetting I thought you did Confused
It wont need resetting if your replacing the airbag ecu Wink
roscoe
PostPosted: Mon Nov 29, 2010 1:26 pm Up
Airbag ECU is that the modulator if not how much will that cost Wink
PostPosted: Mon Nov 29, 2010 1:28 pm Up
Modulator = ecu.
Little silver airbag ecu is under the front ashtray.
Resetting one of these is costly bodging, either unfired 2nd hand unit or new virgin one.
Make sure battery if disconnected before fitting the replacement parts! Laughing
roscoe
PostPosted: Mon Nov 29, 2010 1:30 pm Up
MrBSI wrote:
Modulator = ecu.
Ok thanks
PostPosted: Mon Nov 29, 2010 1:31 pm Up
Get the number from the sticker of your old unit & match it up, being multiplexed you should find a matching one very easily.
Elchippo
PostPosted: Thu Feb 09, 2012 7:10 am Up
Would I have to disconnect the battery? to remove the old airbag ecu from under the ashtray. Just checking before I have a go!
AOwens
Elchippo
PostPosted: Thu Feb 09, 2012 7:14 am Up
The more I think about it is, what if this is not the original, what could I do then to make sure I get the right one??!!
AOwens
Ash
PostPosted: Thu Feb 09, 2012 8:29 am Up
Just test it in a realistic scenario. Smile
SteveTDCi
PostPosted: Thu Feb 09, 2012 9:07 am Up
I think there is a compnay called BBA Reman that can reset them.
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
