Posted: Wed Dec 01, 2010 5:44 am |
Morning all,
Right really need some help...
I used to own a 206 hdi.. then the clutch went so I swapped it for a astra mk4..
Now I want to get a 206 GTi but Im not if I want slightly senible and get a GTi or go all out and get a 180...
Insurance is only £100 difference...
Whats the MPG like on a 180??
and are they much quicker??
Any help thank you
Lewis.
| Astra SXI
HID's
LED Bulbs
Custom Oval Backbox
Irmsher Grille | |
Posted: Wed Dec 01, 2010 5:46 am |
Lewis, there are quite a few threads already about the difference between 138's and 180's.
And what they are like to run & own.
Posted: Wed Dec 01, 2010 5:51 am |
Any links please?
Ive tried searching
| Astra SXI
HID's
LED Bulbs
Custom Oval Backbox
Irmsher Grille | |
Posted: Wed Dec 01, 2010 6:02 am |
My vote goes to a 180.
Get a 138 & after a few months you'll be wishing that you got a 180.
Lewis1600 wrote: |
Morning all,
Any help thank you
Lewis. |
HERE!
Posted: Wed Dec 01, 2010 6:03 am |
Thank you :D
| Astra SXI
HID's
LED Bulbs
Custom Oval Backbox
Irmsher Grille | |
Posted: Wed Dec 01, 2010 6:09 am |
Obviously there are more posts about it, but that is the first that I remembered
Posted: Wed Dec 01, 2010 6:17 am |
Thanks...
Seems like the gti would be the best option really...
cheaper to buy and insure....
hmmmmm... if i see a cheao 180 then its a different story lol
| Astra SXI
HID's
LED Bulbs
Custom Oval Backbox
Irmsher Grille | |
Posted: Wed Dec 01, 2010 6:29 am |
Lewis1600 wrote: |
Thanks...
hmmmmm... if i see a cheao 180 then its a different story lol |
Did you not read that topic then...
The 180 is a far better car.... You can do alot more with it and by the time you got the 138 to the same standard a 180 is you may as well brought 2 180...
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Wed Dec 01, 2010 6:57 am |
180 all the way
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Wed Dec 01, 2010 7:17 am |
Danny224 wrote: |
You can do alot more with it and by the time you got the 138 to the same standard a 180 is you may as well brought 2 180... |
You can do less with the 180 in terms of modifying it.
You wouldn't just tune a 138 to 180 spec though, you'd go further.
In short if you want to keep standard then buy a 180, if you want to modify then buy the 138.
Posted: Wed Dec 01, 2010 7:59 am |
they are 42 different
Posted: Wed Dec 01, 2010 8:07 am |
Kersh wrote: |
they are 42 different |
lol nice joke mate
Posted: Wed Dec 01, 2010 8:23 am |
had a gti got a gt, driven a few 180s the 180 wins hands down in handling, it has more poke and the interior is so much nicer, if your not like me and with insurance being a issue there is no reason to get a normal gti,
| Signature removed due to size | |
Posted: Wed Dec 01, 2010 8:27 am |
ed makes a good point tho 138 is more tunable, but 180s are very cheap now, if you can afford it go for a 180, there not much faster if thats all your after but like i said inside is alot better, mpg is noticeably worse ive heard not owned one so couldnt judge that aspect from experience
