Online Now [63]:
Visitors: 62
Today: 11779
Total: 116591512
Forums › The Car › 206 Talk › Screw rounded off need help
eddrj
PostPosted: Sun Dec 05, 2010 7:00 am Up
Just noticed my air filter box one of the little screws is rounded off cant undo it atall other 3 are ok how annoying , so when next need new air filter or major service cant get it off any ideas ??
Old car 2000/ 206 2.0 hdi.
PostPosted: Sun Dec 05, 2010 7:03 am Up
Mole grips
Grind a slit in it, and use a flat blade crew driver
Drill it out
PostPosted: Sun Dec 05, 2010 7:04 am Up
There's tools that you use like 'Eazy out' that you use after drilling a pilot hole in the screw then use a spanner to undo it.
roberto.f
PostPosted: Sun Dec 05, 2010 7:07 am Up
1) If you can get hold of a stud extractor you MIGHT be able to use that (although i doubt the plastic is strong enough)
2) Drill it out, get a drill smaller than the diameter of the screw and drill from the top.
3) (Can't remember if you can do this on your airbox, as I'm not sure if the tip of the screw is exposed but..) Try using a pair of pliers to turn the screw from the bottom, then you should have enough to turn the screw out from the top with your pliers. - probably your first option.
Hope one of them is of any help
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
eddrj
ok thanks cheers for fast replies
PostPosted: Sun Dec 05, 2010 7:17 am Up
Stud extractor is likely to be too big to get one of the screws out. Just get some mole grips on it. Removing the airbox from the car might help with access.
eddrj
PostPosted: Sun Dec 05, 2010 8:29 am Up
is removing airbox just easy job of them 2 bolts on the left ?? how do i get air box off ??
PostPosted: Sun Dec 05, 2010 10:05 am Up
Mole grips or pliers they aren't on tight.
