Online Now [1187]:
Visitors: 1186
Today: 241986
Total: 150540677
Forums › The Car › 206 Problems › Overheating?
Overheating?
GregorG
PostPosted: Wed Dec 08, 2010 7:52 pm Up
The other day my daft bat of a mother borrowed my car to go to work and returned back at the house a few moments later, smoke pouring from the radiator.
The garage took it in and said it had overheated, and that there wasn't enough coolant in the system so they topped it up and left it sitting for a night.
Got the car back and it drives fine, however whenever the car is at low speed in 1st gear, the engine temperature gauge shoots waaay up to 90 degrees, but then returns to 70ish when driving at higher speeds
common problem or is something properly wrong?
Rob2859
PostPosted: Wed Dec 08, 2010 8:35 pm Up
What engine do you have? how long was the engine overheating? could have caused other damage
panason1c
PostPosted: Thu Dec 09, 2010 3:29 am Up
Sounds like the electric cooling fan isnt working.
Check to see if the electric radiator fan kicks in at about 90, if it doesnt it is probably the thermo switch failed. (or a fuse blown)
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
