Posted: Sat Dec 11, 2010 9:58 am |
how do i remove A B C pillars???? help please
Posted: Sat Dec 11, 2010 10:03 am |
A) Front ones just clip out once you've removed the door seals. Unclip the ultrasonics if you've got them.
B) middle ones clip out once you've taken undone the bolts and remove the seatbelts.
C) Rear ones are exactly the same as the middle ones. Remove the seat belts and just unclip.
Posted: Sat Dec 11, 2010 10:04 am |
IIRC the rear ones have two torx bolts in them as well.
Posted: Tue Aug 30, 2011 3:40 am |
had a bit of difficulty with the middle seatbelts is there a particular way in which to remove them, as in in a particular order of events ... as i seemed to have gotten rather frustrated within two minutes of doing it and snapped one bit of plastic
EDIT: front seatbelts
