Latest: Andyblue64
Overall: 17123
Online Now [401]:
Visitors: 400
Today: 32832
Total: 98401571
Forums › The Car › 206 Problems › starting problems 206 gti
pepsimax
PostPosted: Wed Dec 15, 2010 7:38 am Up
hi im new to this site, just looking for some help or advice, i have a w reg 206gti, it started and drove fine for 2 days, yesterday i went to shop came out and car wont start, all the dashboard lights up, and i can hear a noise from under the bonnett. i discouncted the battery put it back on , still no start. left it a couple of hrs and then it started and drove 50 miles home. this morning it wont start again.... pls help
m.pountney
Big_Rich180
PostPosted: Wed Dec 15, 2010 7:57 am Up
Imobiliser Fault?? Next time it does it try locking the doors then unlocking them and try again.
kieron
PostPosted: Wed Dec 15, 2010 7:58 am Up
sounds like a flat battery is somthing clicking when you turn the key?
get your battery checked and alternator as it couldnt be charging?
has you battery got the magic eye on it if so you can test it by that to see if its at fault
Account suspended
PostPosted: Wed Dec 15, 2010 8:02 am Up
This.
Sounds like the battery.
Will it just not fire up? Will it keep running with your foot on the throttle?
kieron
PostPosted: Wed Dec 15, 2010 8:04 am Up
says it will not start
Account suspended
Big_Rich180
PostPosted: Wed Dec 15, 2010 8:07 am Up
Why would it be the battery if it started again after a few hours?
PostPosted: Wed Dec 15, 2010 8:09 am Up
When my battery went on my 206 GTi, I got it started a couple of times between time it refused to start.
kieron
because batterys work in funny ways have you ever had a flat battery on your phone then a few hours later it will turn on again
same with cars give a a coupe of days it wouldnt turn on
Account suspended
Big_Rich180
PostPosted: Wed Dec 15, 2010 8:10 am Up
Never had it to be honest Laughing
pepsimax
PostPosted: Wed Dec 15, 2010 8:22 am Up
thanks, i will have a look at the battery. if that dont work do you think it might be worth having it scanned, thanxs
m.pountney
pepsimax
PostPosted: Wed Dec 15, 2010 8:37 am Up
batterys fine ? any more ideas
m.pountney
damongoodman
PostPosted: Wed Dec 15, 2010 9:06 am Up
what does the noise sound like?
thanks\r\ndamon
Big_Rich180
PostPosted: Wed Dec 15, 2010 10:31 am Up
Did you try what i said?
pepsimax
PostPosted: Wed Dec 15, 2010 3:15 pm Up
yeah rich, i tried what you said still no luck, thanks anyway. The noise like tic tic tic sounds like its coming from the engine by the coil pack.
m.pountney
