Latest: lio94
Overall: 17181
Online Now [68]:
Visitors: 67
Today: 18896
Total: 140815628
Forums › The Car › 206 Talk › alarm and immobilizor
xrblue
PostPosted: Wed Dec 15, 2010 3:25 pm Up
Hi guys,
My first post, I've had my 04 plate 206 1.4 fever for a good few months now and I have no idea if it is alarmed and/or has an immomiliser, any ideas?
If it is alarmed how can I check to see if it works?
Cheers
2004 1.4i 206
mattievrs
PostPosted: Wed Dec 15, 2010 3:27 pm Up
lock the car with the remote then open the door using the key.If it sounds its got an alarm.Then with the alarm going off put the key in the ignition and turn it.If the alarm stops it has an immobiliser.
NO LONGER ACTIVE ON THE FORUM
xrblue
PostPosted: Wed Dec 15, 2010 3:40 pm Up
Tidy, thanks I'll try it out tomorrow
2004 1.4i 206
cookiemonster
PostPosted: Thu Dec 16, 2010 6:29 am Up
sorry to hijack thread I was having problems with my alarm wasn't sure if working - tried above and YES she works - cheers Mattievrs Smile
Used to be in WRX
PostPosted: Thu Dec 16, 2010 1:12 pm Up
xrblue wrote:
Hi guys,
Cheers
It has a Thatcham Cat 2 transponder key immobiliser fitted as standard.
Sparx206xsi
PostPosted: Wed Apr 04, 2012 1:01 pm Up
Tried the above and no alarm went off. Could this be a fuse problem? Come to think about it I dont think I've heard my alarm ever?!? Help! lol
2003 206 xsi 1.6 16v
PostPosted: Wed Apr 04, 2012 1:53 pm Up
If you don't have a button behind the handbrake that looks like a radar then you don't have one.
Sparx206xsi
PostPosted: Wed Apr 04, 2012 3:11 pm Up
I do have that button Lee. It looks like a wifi button. Thats the internal sensor button, I think, that you push if you want to alarm the car but leave a pet or person in it. Not 100% sure though. Any ideas why my alarm doesnt sound Lee? I tried the above method but no alarm went off when I opened the door using only the key.
Sparx206xsi
PostPosted: Mon May 14, 2012 11:20 am Up
Any ideas guys??
PostPosted: Mon May 14, 2012 11:48 am Up
Sparx206xsi wrote:
Any ideas guys??
XSI has a factory fitted ultrasonic alarm with deadlocks.
Lock the car with the remote ( press the lock button ONCE only! )
Wait 45 seconds then unlock the door via the key barrel, open the door & the alarm should sound.
Your car is multiplexed plus has deadlocks & depending on the BSI software version your car is actually running the alarm system could be armed in either of the following ways.
Early BSI software versions:
Alarm is only armed on FIRST lock button press on remote fob which also sets the deadlocks on your XSI!
Pressing the lock button a 2nd time actually removes the deadlocks leaving the car just normally locked & also disarms the alarm system.
Later BSI software versions for 206's with deadlocks:
Alarm will arm on first ( deadlocking ) or second ( normal locking ) press of lock button on remote fob.
Try again & report back.
Sparx206xsi
PostPosted: Sun May 27, 2012 9:49 am Up
Hey guys sorry about the late reply. Tried the above and no alarm went off :-(. Any ideas?? The red LED on the center console does flash once I've locked the car and it is a XSI model so I know it has got an alarm. Does This sound like a fuse problem?
PostPosted: Sun May 27, 2012 10:02 am Up
Alarm might have been turned off in the BSI configuration setup.
Sparx206xsi
PostPosted: Sat Sep 15, 2012 3:43 pm Up
Is it a simply fix MrBSI?
PostPosted: Sun Sep 16, 2012 3:52 am Up
Needs Peugeot Planet & go in to the BSI configuration setup.
