Latest: Kifi69
Overall: 17183
Online Now [357]:
Visitors: 356
Today: 38373
Total: 143456100
Forums › The Car › 206 Talk › Diagbox v6.01
Diagbox v6.01
jackwetson
PostPosted: Fri Sep 19, 2014 10:05 am Up
Hi!
I have uploaded a VMWare file for all of your enjoyments.
This is Diagbox v6.01 running on XP including a patch for interfaces that will only normally work with up to version 5.29.
Diagbox is pre-activated and ready to go so this should be a simple way for people to get started with diagbox as it can be a pain to install. Please however when opening diagbox DO NOT try to activate, register or upgrade in anyway!
The file is a 4GB rar file and extracts to around 12.5GB.
I'd advise at least a limited knowledge of VMWare to get going with this!
ad.limity.co.uk/1
I'm happy to help out with any questions where I can!
Jack
Diagbox available for use in Stroud, Gloucestershire.
PostPosted: Fri Sep 19, 2014 2:31 pm Up
Is this safe guys?or full of viruses Sad
jackwetson
PostPosted: Fri Sep 19, 2014 2:33 pm Up
It's just a VMWare image, the network adapter has actually been disabled (there isn't any reason to take the virtual XP machine online)
You load it inside VMWare it's not an executable itself.
But of course welcome anyone to validate this Smile
20Drift
PostPosted: Fri Sep 19, 2014 4:09 pm Up
It's just a virtual machine. Used very commonly in business or home labs so that you can have more than one machine running on a computer. All you need to do is get VMWare player and load in this VM - it'll then run a machine within your PC. It runs completely separately to your physical machine, (i.e. it can't access your files etc), unless you share a folder with it.
I've checked it and it's clean, so go ahead and download!
PostPosted: Sun Sep 21, 2014 9:23 am Up
You don't really need to run Diagbox in a virtual machine, it will run happily enough in Window's 7.
I'm up to version 7.52 Wink
[img]
[/img]
The interface is also easy enough to update to version C.
jackwetson
PostPosted: Sun Sep 21, 2014 11:48 am Up
@MrBSI yes obsoulty. But reading through a lot of car forums, most people seem to have difficulty installing diagbox. Hence a pre-installed image that people can get going with fairly quickly and easily Smile
PostPosted: Sun Sep 21, 2014 12:51 pm Up
Plenty of place's to download Diagbox free that install's without any hassle or need for manual activation.
skyecc
PostPosted: Fri Jun 09, 2017 6:15 am Up
Sorry to resurrect this post, but can anyone shed light onto where to download a VM image of PP2000 or diagbox?
