Online Now [1024]:
Visitors: 1023
Today: 55929
Total: 146510875
Forums › The Car › 206 Talk › Stereo Issues
Stereo Issues
Forum Index › 206 Talk
MrrNoName
PostPosted: Fri Dec 17, 2010 5:29 am Up
Hi again, yet another topic within 2 days! i just cant help myself because you guys seem so helpful.
i want to get my stereo out so i can read the serial no off of it, the stereo i have is this one:
www.goauto.com.au/mell...penElement
it only has one pin hole on each side for the "key" to go in. when i search peugeot stereo removal tool on ebay etc it always shows up keys for stereos with 2 pin holes on each side. any idea where i can get a single hole key? or could i buy a double hole key and bend it to just use one side?
ive tried using a metal coat hanger bent etc and cant seem to get it to latch on when i bend the rods outwards.
thanks for your help, i really want my stereo working again and hopefully if i can get it out i can get the serial and in tern get the code Razz
Antknee
PostPosted: Fri Dec 17, 2010 5:51 am Up
try shoving a couple of allen keys in there, both at the same time and when you pull it out push down on the allen keys so they dont just pull out, if you know what i mean! Smile
PostPosted: Fri Dec 17, 2010 5:54 am Up
The the guide I wrote here: 206info.co.uk/Forums/v...=3072.html
roberto.f
PostPosted: Fri Dec 17, 2010 6:01 am Up
Put a couple of screwdrivers down, and use diamond nose pliers to pull it out.
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
MrrNoName
PostPosted: Fri Dec 17, 2010 6:21 am Up
worked after over an hour trying other things! thanks man, finally got the serial no. now to try and get the code!
PostPosted: Fri Dec 17, 2010 6:42 am Up
easiest way is to remove the centre console and unclip it out of it thats what iv always done on my 206s Smile
Antknee
PostPosted: Fri Dec 17, 2010 8:56 am Up
wahayy no probably! finally being useful on the site Very Happy
PostPosted: Fri Dec 17, 2010 9:28 am Up
Just take the whole centre console off, instead of p**sing about with allen keys. Takes literally 2mins to whip that off
