Posted: Sat Dec 18, 2010 10:37 am |
hi iv just tryed 2 in wire up my m3 wing mirrors but i shorted my indicator n im at work at 6pm 2nyt can sme1 tell me wht 2 do 2 sort them
| 1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker | |
Posted: Sat Dec 18, 2010 10:39 am |
just blown the fuse the fuse box is under the cover under the steering wheel turn the little slotted clip 90 degrees and it pulls off the handbook will tell you which fuse you have blown and there should be some spares in there unless soemone in the past has used them and not replaced them
Posted: Sat Dec 18, 2010 10:48 am |
na still na luck mate
Posted: Sat Dec 18, 2010 10:53 am |
If you've shorted the wires, it will be the fuse, you 100% sure?
Posted: Sat Dec 18, 2010 10:58 am |
iv changed the fuse the handbook said it was
Posted: Sat Dec 18, 2010 10:59 am |
When you put the other side indicator on does it flash a lot faster than usual?
Posted: Sat Dec 18, 2010 11:04 am |
it don't flash but it sounds alot faster
Posted: Sat Dec 18, 2010 11:14 am |
sorted thanks alot
