Online Now [868]:
Visitors: 867
Today: 149687
Total: 149765659
Forums › The Car › 206 Problems › SPEEDO
SPEEDO
oldbanger2
PostPosted: Sat Dec 18, 2010 4:57 am Up
my speedo is stuck at 40mph when engine is off and fluctuates at 50 and above when driving. will disconecting the battery reset it??
99 spec gti... Confused
206 gti
ukskater01
PostPosted: Sat Dec 18, 2010 5:25 am Up
Only one way to find out but sounds like it could be a sensor that's faulty, the cluster might be f#%*ed though
oldbanger2
PostPosted: Sat Dec 18, 2010 6:18 am Up
d/c batt. took cluster out & removed plastic glass & moved speed needle back to zero.. reconnected and all is working ok. so moving needle back to zero or d/c battery fixed it for me for now!!
206 gti
PostPosted: Sat Dec 18, 2010 8:22 am Up
It will be the plastic needle is loose on the metal shaft, common problem.
A tiny drop of superglue in the right place is the fix Wink
oldbanger2
PostPosted: Sat Dec 18, 2010 8:31 am Up
the needle was stiff not loose when i moved it back to zero..
206 gti
PostPosted: Sat Dec 18, 2010 8:42 am Up
must have just got stuck, my fuel needle used to do it all the timebit of wd40 sorted it Very Happy
