Latest: tebas93089
Overall: 17179
Online Now [98]:
Visitors: 97
Today: 93973
Total: 137944959
Forums › The Car › 206 Problems › running rich problem
Danpotter
PostPosted: Mon Dec 20, 2010 6:11 am Up
Hi everyone. My car smells like it is running very rich. Ive been told it could be to do with the outside temp gauge. My dash clock dial unit isnt working. Could this be something to do with it or are there other options to try. Cheers dan
Spanerman
PostPosted: Mon Dec 20, 2010 6:15 am Up
Is this only when stating from cold or when the engine has warmed up.
Its normal to run rich for warm up Smile
Hello
Danny.
PostPosted: Mon Dec 20, 2010 6:20 am Up
Is this when running it after awhile or just starting up...
PS: i would delete the other topic...
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Danpotter
PostPosted: Mon Dec 20, 2010 6:21 am Up
when it has warmed up aswell. Not as much tho.
206 gti
PostPosted: Mon Dec 20, 2010 6:51 am Up
The outside temp gauge isnt linked to the engine so it isnt the cause of your running rich problem.
Spanerman
PostPosted: Mon Dec 20, 2010 6:55 am Up
But your coolant temp sender is, and would cause it to run rich, also if the lambda sensor is disconnected it will run rich Smile
Hello
Danpotter
PostPosted: Fri Jan 07, 2011 6:06 am Up
I had my car engine management tested and it had no faults in the system. He said it could be supermarket fuel so he gave me so stuff to put in my tank to clean injectors, sensors ect. It doesnt smell as rich when the engine is nice and hot. Do you think there could be another fault? Cheers
206 gti
