Latest: heikkisj
Overall: 17126
Online Now [202]:
Visitors: 201
Today: 28532
Total: 100361488
Forums › The Car › 206 Problems › water pump
water pump
pepsimax
PostPosted: Mon Dec 20, 2010 12:42 pm Up
hi just wondering how much we are talking to fit a water pump to a 206 gti w reg,
has anyone got a diagram or data for water pump
m.pountney
panason1c
PostPosted: Mon Dec 20, 2010 12:45 pm Up
Dont know the cost but might as well fit a timing belt kit at the same time.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Mon Dec 20, 2010 12:52 pm Up
It's listed as a 5 hour job, and if its about £60 an hour labour, you're looking £300. But like panason1c said, get the timing belt done at the same time
PostPosted: Mon Dec 20, 2010 1:10 pm Up
Independent garage will charge half that for labour.
meady
PostPosted: Mon Dec 20, 2010 2:57 pm Up
Trade Rating: +45
you may aswell do the cambelt kit at the same time as if i renember rightly you have to take the cambelt off or something like that to get to the water pump Sad
TEAM - I HATE FACEBOOK Smile
