Posted: Tue Dec 21, 2010 10:53 am |
Hi All,
Given the current low temps it appears that my windscreen wash system has frozen, i think the motor has frozen too as im not gettting any noise trying to use it!!!
Does anyone know where this is located under the hood so i can attempt to de-frost it before i die in a horrible accident!!!
Cheers Folks
| 1999 206 1.9d I like it!!! | |
Posted: Tue Dec 21, 2010 10:58 am |
Try lifting the wiper off the screen and operating them, often they're frozen to the screen.
Posted: Tue Dec 21, 2010 11:01 am |
the wipers are free and move fine, its the jet system thats the issue!
Posted: Tue Dec 21, 2010 11:04 am |
Have you checked the fuse as mine blew once and there was no noise either
| You never really learn to swear until you learn to drive | |
Posted: Tue Dec 21, 2010 11:21 am |
Washer bottle & motor are inside the drivers side wheel arch behind the arch liner.
Mix some concentrated screen wash with hot water in a 50 / 50 mix & pour it in the washer bottle then leave it for a while.
Posted: Tue Dec 21, 2010 11:24 am |
Motor is located under the trim where your arms are attached. look under the bonnet,on passenger side right at the back, your jets will be frozen! so wil be the screenwash fluid in the bottle, not much you can do accept drive and wait for it to unfreeze
| Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes! | |
Posted: Tue Dec 21, 2010 11:29 am |
bellevuespares wrote: |
Motor is located under the trim where your arms are attached. look under the bonnet,on passenger side right at the back, your jets will be frozen! so wil be the screenwash fluid in the bottle, not much you can do accept drive and wait for it to unfreeze |
No its not there at all
The motor is where MrBSI said.
Just warm the bottle up and the nozzles. Should always have screen wash in it, stops it freezing up
Posted: Tue Dec 21, 2010 11:33 am |
Lee wrote: |
Just warm the bottle up and the nozzles. Should always have screen wash in it, stops it freezing up |
sorry my mistake, WTF. Im thinking of the bloody wiper motor and linkage
Posted: Tue Dec 21, 2010 11:34 am |
Lee wrote: |
sorry my mistake, WTF. Im thinking of the bloody wiper motor and linkage  |
Didnt help the OP put the wrong wording in his thread title
Posted: Tue Dec 21, 2010 11:49 am |
i always thought that sceen wash would stop it freezing but my escort van proved different, could this be cheap screen wash
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Tue Dec 21, 2010 11:54 am |
There's 2 different types of screenwash.
Ready mixed which you pour straight in the washer bottle.
Concentrated which you mix with water yourself in whatever ratio you want.
Concentrated is the best type IF mixed correctly
Posted: Tue Dec 21, 2010 12:00 pm |
concentrated i use , maybe i didnt put enough in as i dont like smell of it,
oh and yeah as above mate, warm water in bottle and over bonnet to defrost the jets and check the fuse
and if it dont work, take a bottle of water with you so you can wash the screen when you stop at the lights !!!! I've had to do this a few times
| Mark
Posted: Tue Dec 21, 2010 12:13 pm |
Apple flavour from halfords, smells lovely
Posted: Tue Dec 21, 2010 12:15 pm |
Lee wrote: |
FLAVOUR does it taste nice???
| Mark
Posted: Tue Dec 21, 2010 12:21 pm |
mjsroofing wrote: |
Lee wrote: |
FLAVOUR does it taste nice??? |
Yep
