Posted: Sun Dec 26, 2010 9:34 am |
Hi can anyone one tell me if the Rolland garros mirrors would have the folding function on my glx preplex. Would it be a case of plugging the mirrors and switch in and away i go
Posted: Sun Dec 26, 2010 2:39 pm |
It depends if the extra wiring is there on your car.
I know the later multiplexed GLX do have the folding mirror wiring, no idea about yours.
Take the trims of the doors to get a look at your electric mirror plugs & see if there's any spare wires on the CAR side of the looms.
You need 2 extra wires on each door to run folding mirrors.
Posted: Sun Dec 26, 2010 2:48 pm |
Thanks for the reply I had a quick look earlier and there are two extra wires in my loom
Posted: Sun Dec 26, 2010 2:56 pm |
davidmonkey wrote: |
Thanks for the reply I had a quick look earlier and there are two extra wires in my loom |
Both side's or just the driver's?
Posted: Sun Dec 26, 2010 5:44 pm |
I have 7wires on driver side and 9wires on passenger side
Posted: Sun Dec 26, 2010 5:45 pm |
thats fine
Posted: Sun Dec 26, 2010 5:54 pm |
Cheers Lee I read a forum a while ago but not one was a hundred percent sure
Posted: Mon Dec 27, 2010 3:14 pm |
Is it possible to buy a repair kit for a folding mirror if the motor doesn't fold
Posted: Mon Dec 27, 2010 3:16 pm |
You also need the folding switch. I have never seen a repair kit for the mirrors.
Posted: Mon Dec 27, 2010 3:21 pm |
I have a set of mirrors and the switch but one of the mirrors doesn't fold so I am hoping to strip it down. But I was wondering if the motor is broken is there anyway of replacing without buying a new mirror
Posted: Mon Dec 27, 2010 3:24 pm |
I have this problem to, unfortuantly you need a new mirror motor
| Team Impossible Possible
Posted: Mon Dec 27, 2010 3:27 pm |
Can you buy the motor separate is it a dealer only part
Posted: Mon Dec 27, 2010 3:28 pm |
You cant even buy them from the dealer as far as i know, you need to buy a new mirror
Posted: Mon Dec 27, 2010 3:35 pm |
IIRC the folding mirrors are around £150 each from the dealers. They only stock multiplex ones now so you'll also need a wiring adapter at around £40 each IIRC.
Posted: Mon Dec 27, 2010 3:55 pm |
Ahhhh the good old non folding electric mirror fault
Easy fix once the mirror is apart
