Posted: Wed Dec 29, 2010 7:36 am |
hey all, I want to purchase and fit some angel eye headlights to my 2001 pre-plexed 206 (1.4 LX)
ive read the guide to fitting them on here:
www.206info.co.uk/Foru.../t=25.html
and also the huge amount of warnings here:
www.body-kit.co.uk/pdf...hooter.pdf
from what i can gather to remove the headlight you have to remove the front grill. then its as simple as a few screws.
ive found some online (see link below) but am not sure what some things in their description mean.
www.autoartltd.co.uk/p...rrentpage=
What does this mean:
" Two sets of wiring harnesses are provided, so lights can fit models with single or twin reflector OE headlights."
also what does this mean:
"This is a replacement lamp for cars with twin reflector headlights & indicator bulbholders with 4 locating lugs (not 3). "
thankyou in advance. I dont want to end up buying the wrong ones and not being able to fit them correctly because they are expensive
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Wed Dec 29, 2010 7:38 am |
MrrNoName wrote: |
" Two sets of wiring harnesses are provided, so lights can fit models with single or twin reflector OE headlights." |
Means you get both the H4 & H7 connectors I think, (Frosted and Crystal OEM light connections)
MrrNoName wrote: |
"This is a replacement lamp for cars with twin reflector headlights & indicator bulbholders with 4 locating lugs (not 3). " |
But from that it sounds like there to replace Crystals and not Frosted - So for Mux'd 206's
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Wed Dec 29, 2010 7:56 am |
Posted: Wed Dec 29, 2010 7:59 am |
Yeah and some of the cars have bot sets of connections on them as well!
What year is your car and do you have clear or frosted lights??
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Ste206 wrote: |
MrrNoName wrote: |
MrrNoName wrote: |
But from that it sounds like there to replace Crystals and not Frosted - So for Mux'd 206's |
Yeah just a tad contradictory, they say they supply H4 & H7 harnesses but they're only a replacement for H7's? :/ would say your safe if you have crystals like ste said but if you have the frosted ones I'd get in contact before you buy
Just go by the date they advise mate and you should be fine
If not it's their problem for advising the wrong date and they'd need to replace them for you
| The Cars:
Posted: Wed Dec 29, 2010 8:02 am |
MrrNoName wrote: |
By the sounds of it you have frosted so would get in contact first
Posted: Wed Dec 29, 2010 8:03 am |
totally dumb question i know but how do i tell if i have crystals or frosted lights?
bit annoying i know but spending my xmas money on em and dont want to mess it up
Posted: Wed Dec 29, 2010 8:06 am |
PUG91 wrote: |
MrrNoName wrote: |
By the sounds of it you have frosted so would get in contact first |
Yeah just go by the dates they advise
spike_202 wrote: |
Audi Sport | |
Posted: Wed Dec 29, 2010 8:10 am |
thats no good if I get them and they dont fit though then I have to pay the postage to post them back! plus the hassle
lol
Posted: Wed Dec 29, 2010 8:11 am |
MrrNoName wrote: |
lol |
Yeah but that would be their error then and they should pay for the postage.
The only thing to do is for you to take a picture of the front end so we know what you have
spike_202 wrote: |
Audi Sport | |
Posted: Wed Dec 29, 2010 8:13 am |
ok, hang on lol
Posted: Wed Dec 29, 2010 8:21 am |
Pretty sure they are frosted.
they DONT look like this:
they DO look like this (hard to see i know):
so that means i have H4 connectors most probably?
so will these lights fit???
confused hahaha
Posted: Wed Dec 29, 2010 8:36 am |
There frosted Ph.1 lights. So yes, your's are H4
| The Cars:
Posted: Wed Dec 29, 2010 8:38 am |
After re-reading it a few times **Slowwwwwwwwwly** It's abit clearer, the advertisement is confusing however; the 4lugs bit is refairing to the indicator holder..
On Phase1 headlights the indictor holder has 4 'lugs' to hold it into the light unit, whereas on Phase2 headlights there is only 3 lugs on the bulb holder for the indicator - Hopefully that'll clear things up..
If you want to double check pop outside and remove the indicator bulb holder and have a look how many lugs it has to hold it into place..
| The Cars:
