Latest: Andyblue64
Overall: 17123
Online Now [144]:
Visitors: 143
Today: 17559
Total: 98289186
Forums › The Car › 206 Problems › Driveshaft gaitor
Driveshaft gaitor
chunkielad
PostPosted: Fri Feb 04, 2011 4:36 pm Up
The O/S inner driveshaft gator has split on my GTi. Looking to swap myself - are there any specialist tools etc and what is the general procedure/ things to look out for please?
Just done the lower arm, drop links and track rod ends now this!
If you do not try you will NEVER succeed!
usher
PostPosted: Fri Feb 04, 2011 4:42 pm Up
if using a universal kit get a cone to slide it on with and plenty of lube
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
thompson69
PostPosted: Fri Feb 04, 2011 4:44 pm Up
hi mat i got the stretchy 1s n thy go over a cone that goses over the cv joint. i think i payed 20 for the boots n cone
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
bellevuespares
PostPosted: Fri Feb 04, 2011 4:45 pm Up
Hows things mate? Do you mean the CV BOOT?
You will see its dead easy if you look underneath. no specialist tools required, you willl have to free the driveshaft though so you slide the new boots on unless you use the cone as stated above.... Take it they've split? are they not clicking on full lock?
Sig removed due to size
PEUGEOT 206 & FIAT PUNTO Replacement Parts at Bellevue Spares Manchester.
We also offer a fitting service! Free Quotes!
chunkielad
PostPosted: Fri Feb 04, 2011 4:48 pm Up
yes it's the CV boot - there are two on the O/S and it's the inner one - I assume I can take the hub off and do it from that end BUT it needs to over the outer one.
