Posted: Thu Dec 30, 2010 4:22 pm |
Oh how I love the way the car gets shaken about like a crazy thing when they do the 'play' tests lol!
All I was thinking is 'jesus I hope that doesnt fly off the edge!'
Glad it passed anyway dude!
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Thu Dec 30, 2010 4:26 pm |
Thanks mate, shame when i got it tracked they did it wrong and it decided it want to head for the other side of the road
Proper blokes they are, they go through the car perfectly but if you have a decat (cough cough) they will let it through
| Team Impossible Possible
Posted: Thu Dec 30, 2010 5:08 pm |
Posted: Fri Dec 31, 2010 12:25 pm |
After market one does look like it is cracking/split slightly. Kyle on the case.
Posted: Fri Dec 31, 2010 12:32 pm |
GP-F wrote: |
After market one does look like it is cracking/split slightly. Kyle on the case. |
Genuine Peugeot parts FTW
Posted: Sun Jan 02, 2011 7:25 am |
Does this look right to you, bearing in mind its on the jack?
IMO it should be further up into the hub (I know the wishbone is tapered so the bolt locates it)??
Posted: Sun Jan 02, 2011 10:40 am |
it doesnt look that bad but grab it and try to move it you shouldnt have to much play or any at all really, try using a bar to wedge in there to test it for movement. its the other two that makes it worse, put wheel on full lock to the right (when sat in car) from outside or he car look through behing the wheel and you can see the rear bush if it looks twisted its shot it should look straight
(oh by the way in your pic your looking at the bottom ball joint.)
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Tue Jun 28, 2011 2:48 am |
i have this exact same problem,i did change the wishbones a few months back with aftermarker ones.The car has just had its mot too and passed.If it is going to the left when changing gear does that mean it would be the passenger side w/b?
Posted: Tue Jun 28, 2011 2:51 am |
GP-F wrote: |
IMO it should be further up into the hub (I know the wishbone is tapered so the bolt locates it)?? |
Looks right to me, I thought is was strange on my 180 but that is just how it sits.
Posted: Tue Jun 28, 2011 2:56 am |
It is right, the other 2 bushes had separated from the metal though!
Posted: Tue Jun 28, 2011 3:17 am |
it could be the camer set up, or track rods?
Posted: Tue Jun 28, 2011 3:49 am |
Check for play in the rear axle it could be the trailing arms. Jack it up and yank the wheels back and forth see if they go in or out. If you can not find play elsewhere just do the wishbones again.
Posted: Sat Dec 31, 2011 1:12 pm |
think im experiencing the same thing on my 206 but it steers right when i change gear
ive had passenger side wishbone changed to ebay aftermarket ones before MOT and was told to change driver wishbone after MOT so changed to aftermarkets one.
so if car is steering right, which wishbone needs attention?
also when im doing full lock right the car feels very strange, must be the ball joints yeh?
| 2003 206 1.4 HDi Style 3 Door | |
Posted: Thu Jan 05, 2012 4:10 am |
bigup wrote: |
also when im doing full lock right the car feels very strange, must be the ball joints yeh? |
anyone?
