Posted: Tue Dec 28, 2010 5:36 pm |
mjsroofing wrote: |
my mate is a pug machanic and he said he has known them to go as quick as a month or two with aftermarket, he laughed at me when i said that i used aftermarket ones. |
Joys, thanks for the info mate
But hopefully it wont be them, cant really afford it as i know it will fail with honors
| Team Impossible Possible
Posted: Tue Dec 28, 2010 5:47 pm |
'tis true I'm afraid aftermarket wishbones are pap Mine have been on less than a month and are already showing signs of wear
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Tue Dec 28, 2010 5:54 pm |
My van did this and was the gearbox diff just giving power to one wheel the it would do both every now and again get the diff checked.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Tue Dec 28, 2010 6:51 pm |
same here! would pull under acceleration to one side then snap back when i lifted off! changed wishbones to genuine ones and changded droplink n all is fine now! u could also check the gearbox mountings to be on the safe side btw
Posted: Tue Dec 28, 2010 6:52 pm |
Lower arms.
Cheap aftermarket ones are s**te, been there done that.
| 206 1400 8v HDi, Battle Bus - More Radical than Peugeot
In theory, there is no difference between theory and practice. In practice, there is. | |
Posted: Tue Dec 28, 2010 6:55 pm |
check the cv joints for lack of grease aswell as checking the gearbox oil level and wouldnt hurt renewing it too.
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Tue Dec 28, 2010 7:39 pm |
Any idea of cost from Peugeot? GSF ones fitted previously (not the cheapest ones they offered either). Discounts available??
Posted: Wed Dec 29, 2010 7:34 am |
It sounds v much like wishbones. The aftermarket ones are poor and the bushes break very quickly. I have heard of them going in less than a week in some cases. Its just your luck if you get a good set
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Wed Dec 29, 2010 7:39 am |
lemforder wishbone from eurocarparts is good as the one from pug dealer
Posted: Thu Dec 30, 2010 10:39 am |
Seabook wrote: |
lemforder wishbone from eurocarparts is good as the one from pug dealer | £100 EACH..hope its not them
Posted: Thu Dec 30, 2010 10:42 am |
GP-F wrote: |
Seabook wrote: |
lemforder wishbone from eurocarparts is good as the one from pug dealer | £100 EACH..hope its not them |
Genuine Peugeot one's are only slightly more.
Last changed mine back in 2005 / 50k miles ago, fit genuine part's & they last
Posted: Thu Dec 30, 2010 10:52 am |
i wouldn't pay £100 each for them though i must admit, i bought two off fleebay for £40 posted, i'd hope for the best. big risk i guess though, at least if pug ones fail you can return them. well i guess you can, i would hope so for that price
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Thu Dec 30, 2010 11:09 am |
without sounding too dumb, what exactly should I be looking for (bearing in mind I dont have ramps - but a trolley jack & axle stands)?
Splits in rubber joints? out of position mounts?
Posted: Thu Dec 30, 2010 11:39 am |
ok, below is a pic of the wishbone, the rubber joint arrowed is normally twisted badley and cracked etc
hope this helps.
| Mark
Posted: Thu Dec 30, 2010 3:13 pm |
Well, mine had an MOT and i specifically stated for them to go over with a fine tooth comb
They did, and found that the bottom arms had no play, same with anyother suspension areas
