Latest: lio94
Overall: 17181
Online Now [107]:
Visitors: 106
Today: 28980
Total: 141112431
Forums › The Car › Request a how-to › Colour coding bump strips
Forum IndexRequest a how-to
206ACE
PostPosted: Thu Dec 30, 2010 1:08 pm Reply with quote Up
hi there i am going to take off the side door stips, bumper bits and colour code them, how do they come off?? and wing mirrors
also any hints/tips would be greatly appreciated
many thanks
PostPosted: Thu Dec 30, 2010 1:09 pm Reply with quote Up
Don't colour code the mirrors do them gloss black, looks odd all white
Ste
PostPosted: Thu Dec 30, 2010 1:12 pm Reply with quote Up
Staff - Ste
^ Wise words Very Happy
The Cars:
Ste
PostPosted: Thu Dec 30, 2010 1:15 pm Reply with quote Up
Staff - Ste
To answer the question though,
The side strips are held on with pop clips, so you just pop them off ( you'll probably break the clips in the process as there pretty brittle - so get some new ones ready Smile )
I think the front bumper mould is held on with clips that slide into the bumper, not sure if there's also a bolt of two on that one, someone will let you know..
And for the rear I have absolutly no idea Sad
The wing mirrors are held in with 3 torx screws behind the plastic cover on the door inslide the car Smile
The Cars:
Mike
PostPosted: Thu Dec 30, 2010 1:17 pm Reply with quote Up
Trade Rating: +28
Or just white the caps? Gloss black base and housing with white caps? Maybe?
PostPosted: Thu Dec 30, 2010 1:19 pm Reply with quote Up
Yer that would work, but when the whole things white it looks a bit tacky, too much white!
Luke
PostPosted: Thu Dec 30, 2010 1:20 pm Reply with quote Up
Three large torx screw located in the boot lip IIRC, then just unclips either side.
JDave
PostPosted: Thu Dec 30, 2010 1:23 pm Reply with quote Up
If you get stuck at all there is alot of threads been made to help people in a similiar situation!
Click To View My Project
PUG91
PostPosted: Thu Dec 30, 2010 1:24 pm Reply with quote Up
The bump strips on the side you need to slide the front ones back (towards the rear of the car) until they move then just pull them off, the rears just pull off iirc.
Front and rear I've never done but you might need to take the grill off and undo some torx screws (can someone confirm??) before popping each corner out of the bumper purely going off what I've seen seen, so could be talking out my a%$e. Similar bolts on the rear too but again, might not have to touch them Smile
PUG91
PostPosted: Thu Dec 30, 2010 1:27 pm Reply with quote Up
And the actual painting the only real tips are too make sure you have more than enough primer, colour and lacquer.
Get a whole bunch of different grade sand paper, and just take everything really slowly, don't skip parts or rush in between coats prep makes perfect Wink
Bailey
PostPosted: Thu Dec 30, 2010 1:31 pm Reply with quote Up
Rear torx is here
Ste
PostPosted: Thu Dec 30, 2010 1:32 pm Reply with quote Up
Staff - Ste
206info.co.uk/Forums/v...14410.html Wink
The Cars:
PUG91
PostPosted: Thu Dec 30, 2010 1:34 pm Reply with quote Up
amazing job mate!!!!
206ACE
PostPosted: Fri Dec 31, 2010 7:32 am Reply with quote Up
thanks for all your help will start that soon and post pics c
cheers
Drives 2005 206 1.4hdi van
  Quick Reply
Username:
Message:
Quote the last message
