Posted: Fri Dec 31, 2010 9:48 am |
Edward wrote: |
Powerflow and other custom outfits do not use mandrel bends. So you new system could well be more restrictive that the original system. |
In a recent Redline issue they tested 3'' systems, a ''crinkle'' bent pipe and a mandrill bent pipe and the crinkle was only slightly down on power as most of the gas flows on the outside of the curve
They had some silly gains on the car though, it was an impreza and they had 30bhp with the off the shelf one
Sam.
Posted: Fri Dec 31, 2010 9:59 am |
If it's for performance gains powerflow are generally pap from numerous years on many forums, for just a factory replacement i'm sure they are ok though, i'd imagine they would be the best bet if you don't want a loud replacement, which is probably why they aren't good for gains (restrictive).
Posted: Fri Dec 31, 2010 12:21 pm |
its just the backbox he wants so mandrel bends dont need to be taken into consideration here? (as apposed to a full system obviously)
Posted: Fri Dec 31, 2010 12:22 pm |
Mine seems fine
Posted: Fri Dec 31, 2010 4:31 pm |
never had problem with mine from fitment to removal 50k later
tbf there have been good/bad comments about most of the 'budget' aftermarket exhaust systems
Posted: Fri Dec 31, 2010 11:28 pm |
No problems at all with mine!
| PM me for Valeting & Detailing services at great rates!
Detailing Guides are also available ask me for more information. | |
Posted: Sat Jan 01, 2011 12:02 am |
customs are s**t mines powerflow at the min and it could be so much smoother piping, my sportex on my old gti was cheaper and much better less piping better bends etc
| Signature removed due to size | |
Posted: Sat Jan 01, 2011 12:03 am |
never read the just a backbox bit, tbh it wont matter too much what you get
