Latest: heikkisj
Overall: 17126
Online Now [60]:
Visitors: 58
Members: 1
Today: 17477
Total: 100301394
Forums › The Car › 206 Problems › anti roll bar drop links
doughboy5
PostPosted: Sat Jan 08, 2011 9:23 am Up
hey have got new ones of these to put on my gti as someone on here the other day said that was what the knocking would be how easy it to change them over? is it just wheel off unbolt old and put on new do i need to grease them or anything or it there anything else that i need to do
thanx
joe
206 GTi
PostPosted: Sat Jan 08, 2011 9:24 am Up
It's not that easy. The old ones are sometimes best being cut off as they tend to corrode. Some copper grease on the threads might make them easier to remove in future.
arronmee1990
PostPosted: Sat Jan 08, 2011 9:29 am Up
Yeh they are a pain to get off if corroded
My Project Thread
doughboy5
PostPosted: Sat Jan 08, 2011 9:33 am Up
alright cool i will wait till the gf's dad gets back as he has all the tools for that job then. cheers for help.
206 GTi
mjsroofing
PostPosted: Sat Jan 08, 2011 3:11 pm Up
just cut the old ones off mate.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Sat Jan 08, 2011 6:17 pm Up
Never really had problems with these, easy job IMO, have done it lots of times.
Had to get a grinder out once tho Laughing
PostPosted: Sat Jan 08, 2011 6:21 pm Up
piece of p**s, change mind the other day
roberto.f
PostPosted: Sat Jan 22, 2011 5:56 am Up
In the process of changing mine right now..
I can't for the life of me undo the nut holding it onto the anti roll bar, if i was to cut the drop link off, surely i still wouldn't be able to undo this nut?
Any prompt help would be amazing, before i go and hire a grinder..
Thanks!
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
PostPosted: Sat Jan 22, 2011 5:59 am Up
You have to basically grind the nut. Wink Not the actual drop-link.
It is not un-common to have them rusted on.
PostPosted: Sat Jan 22, 2011 6:03 am Up
Thanks!
Or use molegrips to hold the ball joint/bolt, while you undo the nut.
roberto.f
PostPosted: Sat Jan 22, 2011 6:20 am Up
Ahh I didn't even think of grinding off the nut!
I'll have a go with mole grips to get it off first.
Thanks to both of you for the quick replies, much appreciated!
doughboy5
PostPosted: Sat Jan 22, 2011 11:08 am Up
when i took my old ones off i noticed it was just spinning but u need a torx key to go in the end of the bolt to hold it still but i didnt notice this till after i grined off the nut. i think it is easiest to grind it off and the just hammer it through.
206 GTi
roberto.f
PostPosted: Sat Jan 22, 2011 11:39 am Up
Well for some reason mine weren't torx, and I didn't have the right attachment to get the right thing in.
That's exactly what I plan to do tomorrow, 7am rise and shine.
DeadEyePaul
PostPosted: Sat Jan 22, 2011 12:20 pm Up
I managed to get the nut to the end of the thread on the bolt before the hex entry on the drop link got chewed. So I got the drill out and drilled the end and the nut fell off.
Here's a tip for you when you jack one side up made sure the opposide side is also same height otherwise the whole process of removing and fitting of them will be more difficult as the car will apply weight to the links
roberto.f
PostPosted: Sat Jan 22, 2011 12:51 pm Up
Yeah that's a good idea.
Well my drive is flat, and it's sat on axle stands both sides so the front of the car is evenly distributed.
