Posted: Sun Jan 09, 2011 6:56 pm |
Today i upgraded my car to leather seats its a 1.1 with the middle seat lap belt in the back but the leather seats in the back have all got the proper seat belts...
Does any one what to bolt the seat belt to or have an idea what to do
Cheers
sorry for the bad description by the way found it hard to explain....
Posted: Sun Jan 09, 2011 7:04 pm |
Lift up the seats that your a**e goes on, you need a buckle there [can't remember which side], uses a 17/19mm bolt to hold the buckle down.
Changeing the seats shouldnt effect seat belts as there not attached to the seats
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Sun Jan 09, 2011 7:07 pm |
right i will try and explain a little better,
The middle seat belt is a proper belt and where the seat belt clicks in at then end of it is like a hole for a bolt to bolt under the seat but as my old interior was just a lap belt all it needed was the clicker/receiver....
Posted: Sun Jan 09, 2011 7:12 pm |
So you've gone from a lap belt to a 3-point one right?
It bolts to the same buckle as the seat on the drivers side.
Posted: Sun Jan 09, 2011 7:16 pm |
yeah gone to a 3 point..
Cheers lee, will have a look tomorrow now...
it ant long at all though its going to have to go bolt to something under the back seats...
it might not bolt to any thing though because it was a lap belt..
Posted: Sun Jan 09, 2011 7:19 pm |
The buckle is bolted to the same bolt as the passengers side one, and the part for the 3-point belt bolts to the same bolt as the buckle for the drivers side.
Posted: Sun Jan 09, 2011 7:22 pm |
I recently did mine.
You will need to swap the clicky thing from the passenger side over to the clicky thing one the drivers side, so you will have two on the drivers side, and one on the passenger side. Then the seatbelt from the rear seat goes where the clicky thing originally was. You should also be able to remove the lap belt aswell as its not needed
hope i explained it well enough lol.
