Latest: DanDan17
Overall: 17128
Online Now [51]:
Visitors: 50
Today: 4282
Total: 100432014
Forums › The Car › 206 Problems › gearbox drive shaft 2 big
martyn..
PostPosted: Sun Jan 09, 2011 2:52 pm Up
gearbox went on me so i got box off ebay that said it was the right 1 and looked same as well but when old 1 was dropped out and new 1 put back in it went in fine drivers side driveshaft went in fine but passinger side driveshaft seems 2 be 2 big is the box from the 1.1 or a diffrent year or sumert like that and can i just put a smaller driveshaft in or is it a new gearbox agen
thanks
1.4 8v 4-2-1 manifold to japcan K&N induction kit droped 60mm on front and 45mm back vortex alloys gti 180 interior halo headlights flush boot number plate moved to botom of bumper and loads of ice
T_bandery
PostPosted: Sun Jan 09, 2011 3:03 pm Up
bigger driveshaft, First time I heard this lol
No all the TU engines use the same box just different ratios
Have you pushed it all the way in?
mattievrs
PostPosted: Sun Jan 09, 2011 5:28 pm Up
Too big or too long?
NO LONGER ACTIVE ON THE FORUM
martyn..
PostPosted: Sun Jan 09, 2011 11:55 pm Up
Too long
mattievrs
PostPosted: Mon Jan 10, 2011 4:18 am Up
by how much roughly? Are they motor factor shafts or pug oem ones?
shr3k1989
PostPosted: Tue Oct 04, 2011 6:07 am Up
Was this ever sorted? Same problem here :/
Shr3k
PostPosted: Tue Oct 04, 2011 11:08 am Up
You referring to his first sentence?
PostPosted: Tue Oct 04, 2011 1:21 pm Up
Shocked
