Latest: Andyblue64
Overall: 17123
Online Now [250]:
Visitors: 249
Today: 22892
Total: 99007184
Forums › The Car › 206 Talk › blower resistor
blower resistor
bashyy1
PostPosted: Wed Jan 12, 2011 10:46 am Up
Hi,
Since i've had my 206, the heating has never worked...i say its never worked... it works ..but on speed setting 4 ONLY. 1,2,3 Do nothing..
I did some research on this and was told i need to replace the "heater motor blower resistor"
I've got this part now, just curious if this is quite easy to do or should i get a garage to do it?
Any ideas welcome Smile
Aegean Blue Gti 180.
Project Thread
robdob
PostPosted: Wed Jan 12, 2011 10:52 am Up
my dad did mine, its reasonably easy to do... you can get access to it through the glovebox if u remove it. but if it sticks u may hav t take the dash out... to be honest it will be cheaper if you do it yourself
PostPosted: Wed Jan 12, 2011 12:04 pm Up
Take the glovebox out [couple of torx screws]
Set the heating to recirculation [the slidy thing, to the right hand side], then you should be able to access it
Turn the resistor and pull it into the duct. Disconnect the wiring, and remove the resistor.
Then refitting is just the reverse, basically
bashyy1
PostPosted: Wed Jan 12, 2011 12:19 pm Up
Thanks for the help Smile
Project Thread
