Latest: sparrowdclxvi
Overall: 17139
Online Now [58]:
Visitors: 57
Today: 83
Total: 112388131
Forums › The Car › 206 Problems › 2.0 hdi still rattling!
Harty
PostPosted: Wed Jan 12, 2011 2:25 pm Up
ok after the jcb incident i decided to fix the car, got the tailgate from bellvue spares as it was my colour and a light (trip from edinburgh to manchester on new years eve Smile ) after i fitted that i got the car into the garage - serviced, front wheel bearings, droplinks and lower arms and track rod ends but the damn thing is still rattling over bumps! It drives excellent but don't want to leave it then something else goes. what else is there on the suspension parts that could be causing this rattle? It's just rough road and the odd bump or 2 that sets the thing off. The springs are fine and the top mounts look good but i'm at my wits end! its the passenger side aswell if that helps any.
Cheers
Chris
Harty
PostPosted: Wed Jan 12, 2011 2:26 pm Up
Its not something stupid like the spare wheel or jack box inside the spare rattling under the rear of the car?
Harty
PostPosted: Wed Jan 12, 2011 2:27 pm Up
nope because i had no spare wheel and i've now added the cage and wheel in but it's done it the whole way through Sad
Harty
PostPosted: Wed Jan 12, 2011 2:31 pm Up
maybe it your engine cover Smile
Harty
PostPosted: Wed Jan 12, 2011 2:44 pm Up
lol engine cover aint on Razz when i go over a bump its like something bouncing if that helps and the car pulls to the right when it decides to rattle lol
Harty
jjhj306
PostPosted: Wed Jan 12, 2011 3:26 pm Up
Anti roll bar mounts maybe?
206 HDI
Harty
PostPosted: Wed Jan 12, 2011 3:29 pm Up
i was thinking it might be a bush on the ARB but garage said they checked it and it was fine, might get a second opinion but other than that i'm getting very annoyed with it because whenever the garage test drives it, it doesnt do it! i might have to take one of them out in the car with me because it does it for me every single time i drive it!
cheers
chris
Harty
jjhj306
PostPosted: Wed Jan 12, 2011 3:32 pm Up
sods law mate, ya could always turn the radio up Wink if i can think of anything else i will post Smile
206 HDI
Harty
PostPosted: Wed Jan 12, 2011 3:35 pm Up
yeah the garage told me i could do that too which i kinda thought was cheeky since they're meant to fix problems not just ignore them lol
what else is there to do with the suspension i can check? mainly in contact with the wheel
cheers
Chris
Harty
vanman_foci
PostPosted: Wed Jan 12, 2011 4:07 pm Up
Drop links?
Harty
PostPosted: Wed Jan 12, 2011 4:13 pm Up
changed Smile
Harty
stevedude
PostPosted: Tue Jan 25, 2011 9:56 am Up
drive shaft, the bit that the hub goes onto!
i had one that was worn all way throu, only thing keeping wheel on was caliper, and a garage missed it when i ask em to check for the bang, get ya hubs off and check
Happydays
bedlam
PostPosted: Tue Jan 25, 2011 1:41 pm Up
omg...my cars doing the same thing
thought i fixed it by removing spare and fixing cage but its still there
any idea how much a garage would charge to change antiroll bar bushs?
if it is that
good day darling
PostPosted: Tue Jan 25, 2011 2:07 pm Up
Did you change the top mounts and bearings?
