Latest: lio94
Overall: 17181
Online Now [64]:
Visitors: 63
Today: 22345
Total: 141461385
Forums › The Car › 206 Problems › normal oil temp
normal oil temp
PostPosted: Sat Jan 15, 2011 7:18 am Up
Went on a short drive from plympton to lee mill and on the way back noticed my oil temp gauge was 90 degrees, is this normal for such a short distance i.e. 5miles?
robdob
PostPosted: Sat Jan 15, 2011 8:14 am Up
im glad someone else has put this up. i have a similar problem with mine as in worried about oil temp. my guage reads around the 80 degree mark till i get to about 70 mph and then it reads between 85 and 90 ish. so tbh mines about 80 mate Smile
PostPosted: Sat Jan 15, 2011 8:36 am Up
90 degree oil temp is fine, stop worrying.
Jayyy1989
PostPosted: Sat Jan 15, 2011 9:11 am Up
mine 80, 90 max when im p**sing about reverse parking in town
Jay Kane
Bassline_Toad
PostPosted: Sat Jan 15, 2011 9:25 am Up
Normally, Mine never goes higher than like 40 degrees.
When I'm in traffic it rises dramatically.
PostPosted: Sat Jan 15, 2011 10:10 am Up
Highest i've had the oil temp go was 115 degree's, I had been tanking it down the motorway for the last hour Laughing
Coolant temp at the time was sitting around 90 degree's.
Just round town once warmed up the oil temp sit's around 90 degree's
PostPosted: Sun Jan 16, 2011 8:35 am Up
will get hot quick mate as you were straight out onto the a38 at high speed i should imagine Razz
mine normally takes a couple of miles to get up to 90 and then sits at that unless im driving really hard in which case it will creep up to just over 95 then once i slow down it drops straight back to 90
nothing to worry bout mate Smile
PostPosted: Sun Jan 16, 2011 8:48 am Up
40 degree oil temp? Laughing
chunkielad
PostPosted: Sun Jan 16, 2011 9:10 am Up
both my oil and water guages are rock bottom when I am moving. They only creep up when I am stationary. I think someone has been in the dash though so the needles could be wrong.
If you do not try you will NEVER succeed!
