Online Now [50]:
Visitors: 49
Today: 17293
Total: 117130755
Forums › The Car › 206 Problems › loss of power/ boost
sgwilson
PostPosted: Fri Jan 14, 2011 4:56 pm Up
could do with a little help. my 2.0 hdi is down on power and hits a flat spot after 3 grand. has been like this as long as i had it and my friend noticed it the other day when he was driving it. any help would be much appriciated. have a feeling there is something wrong with the turbo, or something stopping the turbo from boosting propperly. thanks very much again
peugeot 206 2.0 hdi 51 plate
PostPosted: Fri Jan 14, 2011 5:11 pm Up
stock turbo kick in after 1.5K rpm, full boost after 2K rpm. it is normal if you don't feel much power after 3K
PUG91
PostPosted: Fri Jan 14, 2011 5:14 pm Up
What He Said
I shift at 3k revs as the turbo's run out of puff by then, think it's normal on the 2.0l HDi. Mines been like that since I got it Smile
sgwilson
PostPosted: Fri Jan 14, 2011 5:16 pm Up
cheers. mate reckons its low on power got any ideas? as see you hunting for a 106 and 205 I've got both pm me
PUG91
PostPosted: Fri Jan 14, 2011 5:35 pm Up
I don't think there's any issues to be honest mate, where abouts in shropshire are you? could go for a spin and se if there's any difference if your not too far away
sgwilson
church stretton
PUG91
PostPosted: Fri Jan 14, 2011 5:39 pm Up
ah right, I'm in market Drayton so a good 35 miles away lol. Like I say I don't think you have an issue but if your really concerned about get it on a diagnostic machine
sgwilson
PostPosted: Fri Jan 14, 2011 5:42 pm Up
not majorly as it still goes and its only a car for pootling around in, got the rally car for thrasting about in.... mind you its in bits atm. cheers for the help mate!
Mitch
PostPosted: Fri Jan 14, 2011 6:52 pm Up
How many miles are on the car?
Tom206
PostPosted: Fri Jan 14, 2011 7:47 pm Up
Ive got s 2.0HDi.... mines the same between 1.5k - 2.5k is the strongest... after that its dead... its got pure mid range pull... crap acceleration and okish top end... im thinking a rempap will sort that out...but its a good £350-400!
2002 2.0 HDi SP
www.facebook.com/tomwebb01
apjs87
PostPosted: Fri Jan 14, 2011 11:42 pm Up
What the hell is a rempap???
Mine is the same as above. Don't think u have an issue as long as it boosts in between the above rev range
No longer a 206 owner
Astra H sxi. 1.7Cdti
sgwilson
PostPosted: Sat Jan 15, 2011 8:23 am Up
yer from what you all say seems its just has a little less power than i was expecting. cheers for all tihe info has helped alot!!
Aar_Im_A_Pirate
PostPosted: Sat Jan 15, 2011 1:04 pm Up
Does the car pull well on a cold day?
On a cold day my hdi is quick enough, but like you I have little power after 3k on warmer days
Team: Derv
PostPosted: Sat Jan 15, 2011 1:09 pm Up
a remap will not sort that out.
the peak torque is still between 2K and 2.5K
sgwilson
PostPosted: Sat Jan 15, 2011 1:16 pm Up
I think it has a little less go than I was anticipating. cheers again
