Latest: DanDan17
Overall: 17128
Online Now [255]:
Visitors: 254
Today: 25034
Total: 100625440
Forums › The Car › 206 Problems › Auto electric windows
ukskater01
PostPosted: Sat Jan 15, 2011 9:26 am Up
Hi guys and girls, I've got a 2001 y reg lx with the electric mirrors and windows switch, it has the A on the drivers side button for the window but it has never worked. It seems to be just a normal switch.
Is there any way to get this working? I'm thinking the owner before me may have installed the switch but I'm not sure if a lx is suppose to have it?
Thanks for your time
PostPosted: Sat Jan 15, 2011 9:28 am Up
What happens if you give the drivers switch a quick press down?
ukskater01
PostPosted: Sat Jan 15, 2011 10:13 am Up
It does down a tiny bit Sad
PostPosted: Sat Jan 15, 2011 10:18 am Up
It should have one shot window as it was standard fit on the LX of this vintage.
You giving the switch a light or hard press?
Just gently tap the switch.
PostPosted: Sat Jan 15, 2011 2:09 pm Up
I guess your switch is not the original one,and your window regulator don't have the "Auto" function,and it's not a easy job to do by the way,so keep it as it's
mattievrs
PostPosted: Sat Jan 15, 2011 2:24 pm Up
Have you reset the one shot auto? pull the switch labelled A up to do the window up then hold the switch in the pulled up position for 5 seconds then try the auto feature
NO LONGER ACTIVE ON THE FORUM
ukskater01
PostPosted: Sat Jan 15, 2011 3:49 pm Up
I just tried what you said mattie, when I hold it up for 5 seconds i hear a click, I then tap it to go down but the windows doesn't do anything, I tap it two or three times more then it starts working but just goes down a little bit like before?
mattievrs
PostPosted: Sat Jan 15, 2011 4:39 pm Up
dont tap it mate, push it all the way as the switches have 2 stages. the first is non auto and the second which is a full press is auto.
PostPosted: Sun Jan 16, 2011 5:55 am Up
That would blow the fuses if that happened Wink
Like Mattie said, the switch has two stages. Pull/push it all the way, you can feel the switch 'click' when its in auto function.
ukskater01
PostPosted: Sun Jan 16, 2011 10:17 am Up
It's working now Ive reset it properly and pushed it properly like mattie said
thanks a lot guys, helpful as always!
mattievrs
PostPosted: Sun Jan 16, 2011 11:00 am Up
Thumbs Up
PostPosted: Sun Jan 16, 2011 12:58 pm Up
I remembered that after I posted it..lol,i think you told me that once yourself Very Happy
