Posted: Sat Jan 15, 2011 7:18 am |
Went on a short drive from plympton to lee mill and on the way back noticed my oil temp gauge was 90 degrees, is this normal for such a short distance i.e. 5miles?
Posted: Sat Jan 15, 2011 8:14 am |
im glad someone else has put this up. i have a similar problem with mine as in worried about oil temp. my guage reads around the 80 degree mark till i get to about 70 mph and then it reads between 85 and 90 ish. so tbh mines about 80 mate
| Smoothed & Clean or Nothing at all | |
Posted: Sat Jan 15, 2011 8:36 am |
90 degree oil temp is fine, stop worrying.
Posted: Sat Jan 15, 2011 9:11 am |
mine 80, 90 max when im p**sing about reverse parking in town
Posted: Sat Jan 15, 2011 9:25 am |
Normally, Mine never goes higher than like 40 degrees.
When I'm in traffic it rises dramatically.
Posted: Sat Jan 15, 2011 10:10 am |
Highest i've had the oil temp go was 115 degree's, I had been tanking it down the motorway for the last hour
Coolant temp at the time was sitting around 90 degree's.
Just round town once warmed up the oil temp sit's around 90 degree's
Posted: Sun Jan 16, 2011 8:35 am |
will get hot quick mate as you were straight out onto the a38 at high speed i should imagine
mine normally takes a couple of miles to get up to 90 and then sits at that unless im driving really hard in which case it will creep up to just over 95 then once i slow down it drops straight back to 90
nothing to worry bout mate
Posted: Sun Jan 16, 2011 8:48 am |
albackjcb wrote: |
When I'm in traffic it rises dramatically. |
40 degree oil temp?
Posted: Sun Jan 16, 2011 9:10 am |
both my oil and water guages are rock bottom when I am moving. They only creep up when I am stationary. I think someone has been in the dash though so the needles could be wrong.
