Latest: dreyfalon
Overall: 17121
Online Now [539]:
Visitors: 538
Today: 43127
Total: 97343196
Forums › The Car › 206 Talk › few gti 140 and 180 questions
Go to page Previous  1, 2
giveitsomebar
PostPosted: Sat Jan 22, 2011 5:45 pm Up
brilliant answer sab thanks thats helped me out alot! 138 engine it is!! i have a 138 now and i do like it just didnt know how easy it was to get 160 bhp from them!
PostPosted: Sat Jan 22, 2011 5:56 pm Up
easy, mid-cam+remap. job done
Mr_Cellexe
PostPosted: Sun Jan 23, 2011 4:33 am Up
For road rallying, why not just buy a lamp pod? (esp if vision is that important).
tbh, the 180 is gonna be a pain in the a**e if you wanna mess about with the engine (VVT is causing problems for Jamie atm i think).
Get a non plexed 138, its much much easier to work on and will more than likely cope better with your mods. 160 shouldnt be much more than cams, TBs and standalone management.
Tbh, if you strip out as much as you can from the interior, rollcage it, uprate brakes/pads. you'll see a massive improvement over standard form just from that.
PostPosted: Sun Jan 23, 2011 4:38 am Up
I'd expect a fair bit more power with those modifications!
For a reliable 160-180 bhp then I'd just go for a standard 180 engine.
PostPosted: Sun Jan 23, 2011 6:31 am Up
is there any restriction in engine mod?
Spanerman
PostPosted: Sun Jan 23, 2011 6:42 am Up
You cant use a lamp pod for road rallies, and all of the major interior parts much remain in Smile
Sam
Hello
giveitsomebar
PostPosted: Sun Jan 23, 2011 6:47 am Up
yep for road rallying the rules are quite strict.
no lamp pods
no discharge lights unless the car come out the factory with them
no lightforce lights
interior must still have rear seats and most of the trim
engine mods are anything goes aslong as you dont change it from the original fueling system so you cant put ITBS or turbos or anything like that.
there is a guy who runs a 206 cup car and as they were produced by peugeot he can run everything that it come out the factory with like the cup inlet manifold and stuff but he has to stick to the 1600 engine, i think he has got about 190bhp but the engine lacks torque and doesnt seem to come on cam untill about 3500 rpm!
www.youtube.com/watch?v=NB-e0xW79aw
thats him on one of the few daylight sections we use not very impressive but you get the idea Smile
thanks for all your input so far
PostPosted: Sun Jan 23, 2011 7:49 am Up
no lamp pods
but to be fair, power from 3500 all the way down to 9000 is pretty amazing, plus i don't suppose you have much time using rpm below 3500 in rally?
giveitsomebar
PostPosted: Sun Jan 23, 2011 7:55 am Up
you would be surprised we get alot of tight hairpins and controls which requires alot of stop starting so something with less than 190 bhp but more torque would defiantly benefit on some of the more tighter stages
PostPosted: Sun Jan 23, 2011 8:09 am Up
Razz always learn something new in here!
Mr_Cellexe
PostPosted: Sun Jan 23, 2011 9:12 am Up
Hmm...seems a bit pointless using a 138 then
tbh, didnt have a clue on the restrictions for RR.
giveitsomebar
PostPosted: Sun Jan 23, 2011 10:13 am Up
does anyone know the exact power and torque figures for the 2 engines?
-Tom-
PostPosted: Sun Jan 23, 2011 10:36 am Up
Parkers It's all on there, facts and figures section
Moonstone GTI . . . SP grilles, ss cat-back, quick shift, ECU re-map. Trying to resist the modding bug this time and failing!
Z4 3.0si, 06
Quarmbo
PostPosted: Sun Jan 23, 2011 12:29 pm Up
Have a look at Mac's rally 206 gti for engine mods
Ford SportGay-A
PostPosted: Sun Jan 23, 2011 12:38 pm Up
mac is do grp A stage rally i think, engine mod regulation is different
Page 2 of 2
