AsphericSmile wrote:
DJ- wrote:
bearing in mind with crystals youll have to find or make adapters so you might aswell read up on that first. angels will be plug and play.... of course providing your car has frosted as standard. could check if h7 looms are in engine bay mind.
Mine weren't plug and play. They were a nightmare to wire in lol.
well plug and play for the beams. of course the halos will need splicing into the sidelight wiring
That was the easy bit, there is just a plug in which you plug the side light wire into, this then feeds the halos and the side lights.
The beams were the harder bit, the original lights are a single bulb, the angels have separate high and low beam bulbs.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
