Posted: Mon Jan 24, 2011 2:09 pm |
Right, I'm screwed!
Exhaust started blowing this morning and having popped in to those lovely lads at Kwik Fit it seems I need a whole new exhaust.
£404 fitted
Anyone know where I can get one on the cheap (2nd hand, whatever). It appears that for this model of car it comes as a complete part.
Please, please, please help me!!!
Posted: Mon Jan 24, 2011 2:11 pm |
Try a DECENT exhaust place
Kwik fit are expensive as they work on a bonus scheme
Local motor factor, Euro car parts or GSF will sell you the parts.
Posted: Mon Jan 24, 2011 2:12 pm |
GSF ftw.
Posted: Mon Jan 24, 2011 2:14 pm |
kwik fit are proberbly lying. Take it to a decent garage as already said. you will find its proberbly just a backbox or something minor
Trade Rating: +45
u could get a nice custom made stainless steel one for less than tht, and you will never have to worry bout replacing it again
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Couldn't find it on the GSF website, only smaller engine models.....
Anyone able to point an amateur to it please?
Posted: Mon Jan 24, 2011 2:16 pm |
Rob2859 wrote: |
kwik fit are proberbly lying. Take it to a decent garage as already said. you will find its proberbly just a backbox or something minor |
No, definitely not. I got under to have a check and its broken off just before the back box and there is a hole in the bit in the middle of the car that the pipe runs from to the back box.
All completely unweldable due to rust
Posted: Mon Jan 24, 2011 2:34 pm |
kwik fit suck, they are so over priced! i got a new one fully fitted for a third of that on my 1.4 deffo try another garage!
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Mon Jan 24, 2011 3:12 pm |
Posted: Mon Jan 24, 2011 3:21 pm |
SteveM wrote: |
Rob2859 wrote: |
All completely unweldable due to rust  |
then you just need a new centre pipe unless it snapped on the backbox too. the cat and front pipe should be fine. even if you replace the front pipe as well the cat will not need replacing until it fails the mot.
Posted: Mon Jan 24, 2011 3:31 pm |
Hi Rob,
Using my limited powers of explanation, there is a box at the rear that sticks out the back of the car (A), A pipe that runs from it down the centre of the car (B) and a box towards the front of the car that the pipe connects to (C).
From the front of the system backwards..... there is a hole in C, C connects to B fine but B is completely detached from A at the point where the two meet.
Rob2859 wrote: |
SteveM wrote: |
Rob2859 wrote: |
then you just need a new centre pipe unless it snapped on the backbox too. the cat and front pipe should be fine. even if you replace the front pipe as well the cat will not need replacing until it fails the mot. |
Posted: Mon Jan 24, 2011 3:34 pm |
Just do the cheeky trick, beans tin, Gun Gum exhaust tape can get it from most places even halfords, and 3 jubilee clips!
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Mon Jan 24, 2011 3:35 pm |
what that is a real p**s take def be cheaper any other place surely, can get new backbox for £35 ebay new duno how much is middle part though aswell def should be half that price at a good cheaper place
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Mon Jan 24, 2011 4:10 pm |
Posted: Mon Jan 24, 2011 8:18 pm |
[quote="SteveM"]Hi Rob,
[quote="Rob2859"][quote="SteveM"]
Rob2859 wrote: |
A = front pipe
B = centre pipe
C = Backbox
Before the front pipe is the CAT; this is pretty expensive but proberbly will not need replacing. You are saying the backbox has come off the rear end of the centre pipe. It is proberbly down to the clamp rusting away rather than the hole pipe breaking off.
So in short you need a front pipe and backbox
Posibly a centre pipe and proberbly not a CAT.
Unless the centre pipe has recently been done you are proberbly better of replacing all of it AFTER the CAT. The CAT is by far the most expensive part of the lot so make sure that is not replaced if it doesn't need to be. I suggest buying the parts and taking it to a good garage to have them fitted.
