Posted: Wed Dec 22, 2010 11:10 am |
about a week ago my abs light came on along with the esp/asr
my brother did a diagnostic check and came back as left front sensor fault
so rung around a few places and the was all 40-50 pound
peugeot was £28 so better than after market and with a trade discount it was even cheaper
so its worth a call to peugeot just to check the prices
problem solved
thanks
Posted: Wed Dec 22, 2010 11:13 am |
A lot of people stupidly forget to check the main dealer prices on items & get ripped off.
There's a lot of people out there & on here who think Ebay is always cheaper, just take trim clips for example
A lot of the newer Peugeot / Citroen stuff the ABS sensors are very cheap to buy from the main dealer as you have found out
Posted: Wed Dec 22, 2010 11:17 am |
Phase two washer jet and arch extension clips are other ones as well, where people think eBay are cheaper
Posted: Wed Dec 22, 2010 11:38 am |
Trade Rating: +45
Yeh i just bought two of the mist washer jets and the were £9. Whereas on ebay the try and sell them for £17
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Wed Dec 22, 2010 1:09 pm |
Well i think that the dealer price should be the first choice always,if you find it too high,then you look for after market one,so that you compare the prices,and if the price is close,or even the dealer is a bit higher,then we should go with dealer and original part,so glad your problem were solved
Posted: Wed Dec 22, 2010 1:29 pm |
some stuff from dealers is ok some other stuff like disc and pads are quite expensive ive found
its just if you go to your local motor factors you get it there and then and peugeot always take 2-3 days. this time i waited but if they is only a few quid in it ill go to the motorfactors every time
Posted: Wed Dec 22, 2010 5:36 pm |
Alot genuine stuff is cheaper then after market on all makes like a genuine audi a3 water pump round £39 + vat and a after market one round £50 + vat and aint very good compared to geunine one.
i atend to only use genuine part even if they more money than a cheaper after market one just because i know it will fit 100 % right and have no problems, unless the customer cant afford it and like my bro just said alot of stuff has to be order in from the mean dealers and take couple days and after martet part shops atend to have most stuff in stock.
kyle
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Wed Dec 22, 2010 6:18 pm |
I had the same problem. Was the same sensor on mine!!!
Left front.
Made the brakes go strange one time, like abs was stuck on. Very scary.
Can't believe how many jobs one sensor does!!!
Posted: Thu Dec 23, 2010 6:23 am |
| mattymj wrote: |
Can't believe how many jobs one sensor does!!! |
The ABS & ESP are part of the same system, that hydraulic block behind the passenger side headlight does both
Posted: Sat Feb 12, 2011 8:34 am |
i recently has the bsi unit changed on the car
the esp now flashes and doesnt work.
the garage claim the sensors for the esp are fine near the wheel but there's some problem they cannot figgure.
if the abs work ok does this mean when they programed the bsi that they may have messed up with the esp.
answers anyone please.
this has already cost me £600 and they want more to persue the problem
Posted: Sat Feb 12, 2011 8:50 am |
I changed the clutch in my mates 307sw. He phoned everyone MF locally but i told him to give Peugeot a ring in Abergavenny, they were£40 cheaper than anywhere else. I check the dealers 1st every time.
Posted: Mon Apr 04, 2011 4:02 pm |
Hi Kieron. I am in Central America and Peugeot dealer here is very special, high prices and very low service. As an example, I change my front abs sensor and it cost me US $ 97 !
Do you know if there is a way I can buy by internet from the dealer you bought it and send it overseas?
BTW. I think I´ll need to change my two back wheel abs rings
| Carlos\r\nPeugeot 206 s16 2004 | |
