Latest: Andyblue64
Overall: 17123
Online Now [98]:
Visitors: 97
Today: 19905
Total: 98023908
Forums › The Car › 206 Problems › my 206 nightmare...help!!!
jkearns554
PostPosted: Wed Jan 26, 2011 1:14 pm Up
ok so my 206 is a 1.4 hdi, and i was looking if anyone maybe knew why it switches itself off after hitting some bumps, normally only happens when the engines cold, and last night it also put the fuel tank down by about a quater Confused anyone know the reason to this problem, help urgently needed
eddrj
PostPosted: Wed Jan 26, 2011 1:17 pm Up
may be the air flow maf sensor
Old car 2000/ 206 2.0 hdi.
jkearns554
PostPosted: Wed Jan 26, 2011 1:18 pm Up
whats that? lol
jtd
jkearns554
PostPosted: Wed Jan 26, 2011 1:19 pm Up
oh and also sometimes the airbag light comes on and i think there's an engine mount loose, it have anything to do with it?
jtd
PostPosted: Wed Jan 26, 2011 1:20 pm Up
it sure do
eddrj
PostPosted: Wed Jan 26, 2011 1:27 pm Up
measures amount of air going into inlet manifold and then sends signal to other compoments making sure engine is running correctly . Signs are poor idling, black smoke,loss of power or cutting out at slow speeds at roundabouts bumps or wotever.
They £40 new on ebay but youd probably best take it to garage could be some other reason though few things , just a guess , when was it last serviced?
also make sure air filter and fuel filter arent all blocked up, also need to get engine mount looked at and sorted if its loose
NICKST
PostPosted: Wed Jan 26, 2011 2:37 pm Up
Is it not a dodgy fuel cut off switch as bumps can activate it.
PostPosted: Wed Jan 26, 2011 2:39 pm Up
my mates saxo had no suspention travel that bumps used to set it off all the time Laughing
bypassed it in the end Shocked
