Latest: Andyblue64
Overall: 17123
Online Now [349]:
Visitors: 348
Today: 16453
Total: 98020469
Forums › The Car › 206 Problems › handdbrake light...again
SarahW
PostPosted: Wed Jan 26, 2011 10:09 am Up
Recently posted about my handbrake light flickering all the time, appeared to just be brake fluid however its just started doing it again and I only filled it up a few weeks back?
anthony_839
PostPosted: Wed Jan 26, 2011 10:11 am Up
check it isnt low.... if it is then you have a leak
euroed astra
dturbopeck
PostPosted: Wed Jan 26, 2011 10:15 am Up
youve probly got a leaky rear brake cylinder, or a leaking brake pipe, best get it checked out.
eddrj
yeah usaully happens when brake fluid really is low ,better check for leaks or take it to a garage
Old car 2000/ 206 2.0 hdi.
PostPosted: Wed Jan 26, 2011 10:20 am Up
could be anything else if it isnt the brake fluid. Handbrake switch or even low brake pads I believe for that matter.
stevedude
PostPosted: Wed Jan 26, 2011 10:22 am Up
on the 306 haynes, it says it could be the battery is not getting enough charge, belts to loose, alt is shagged. i left it on 306 for a couple months, then scrapped the b***h lol
Happydays
SarahW
PostPosted: Wed Jan 26, 2011 2:13 pm Up
haha, i only had a leaking cylinder replaced a few month back, i'm sick now...think she's gunna have to go the journery soon =(
SW.
2Oh!6
PostPosted: Wed Jan 26, 2011 2:14 pm Up
Brake pads.
VTEC goes BWAAAAAAH! Wink
Just the 1 replacement cylinder?
Its always a good idea to do them in pairs, if ones leaking the other wont be far behind Wink
sillyhilly
PostPosted: Wed Jan 26, 2011 2:16 pm Up
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
BRAKE PADS!!
I said this in the last message - it sounds textbook pads.
Hi Mikey Smile
SarahW
PostPosted: Wed Jan 26, 2011 2:20 pm Up
woahh ok haha, i'll get the brake pads checked then! how much do you reckon to get them done at a garage?
SW.
PostPosted: Wed Jan 26, 2011 2:21 pm Up
if it is pads, you might aswell get the discs done too whilst its all apart.
i paid 45 for fitting of both + parts(around45-50)
PostPosted: Wed Jan 26, 2011 2:23 pm Up
Id be tempted to swop the handbrake switch for the glovebox one as there has been no mention of the STOP light coming on as well.
PostPosted: Wed Jan 26, 2011 2:24 pm Up
i though 1.4 8v has got drum at the back? Confused
PostPosted: Wed Jan 26, 2011 2:28 pm Up
woops i didnt check what car she had Embarassed
