Posted: Thu Jan 27, 2011 9:54 am |
Posted: Thu Jan 27, 2011 9:56 am |
Mine says 800bhp mode
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
Posted: Thu Jan 27, 2011 9:58 am |
There was a few threads about this on the old Info site. It just means there's a problem with your car, get the fault codes read or a good service, that should fix it. FYI, I'm still trying to find the Veyron button on my car
Posted: Thu Jan 27, 2011 10:00 am |
Jay794 wrote: |
There was a few threads about this on the old Info site. It just means there's a problem with your car, get the fault codes read or a good service, that should fix it. FYI, I'm still trying to find the Veyron button on my car |
Incorrect.
The car goes into Eco mode to save the battery so there is enough charge to start the car.
Eg if you're sitting in the car with the radio on for 20 mins or so the car will go into eco mode & disable some functions such as the radio & lights.
Posted: Thu Jan 27, 2011 10:01 am |
lol there's lots of problems with my car, anything more specific
what it mean that say you leave your doors open or inside light on etc it will go into eco mode so your battery will not go flat
EDIT beaten to it!!!!!!!!!
Posted: Thu Jan 27, 2011 10:02 am |
so battery is low?
CD-vRS wrote: |
Jay794 wrote: |
Incorrect.
Eg if you're sitting in the car with the radio on for 20 mins or so the car will go into eco mode & disable some functions such as the radio & lights. |
How is that incorrect? surely if your battery is low on power that is classed as a problem?
what i would do to have a small screen to tell me whats wrong with my car i cant even have the fault finder thing put on my car its all about using your damn eyes and ears
Posted: Thu Jan 27, 2011 10:03 am |
there is not a problem with your car! lol there is a 30 mins time-out on power when engine is not running. using the radio, courtsey light etc.. when the engine is not running will be cut off after 30 mins or so. start the engine and it resets the timer.
there is no by-pass for this feature, which is annoying, but it saves your battery dying if you leave your lights on.
it will do this if the battery is low or brand new
| GTi 180 - Scorpion Exhaust | |
Posted: Thu Jan 27, 2011 10:06 am |
thanks lingo, and everyone else of cause, well thats a good thing.
lol i do have an alarm in car, i was working on stereo/speakers other day, alarm went off, BUT i was in car a good 30 mins before that lol
Jay794 wrote: |
CD-vRS wrote: |
Jay794 wrote: |
Incorrect.
How is that incorrect? surely if your battery is low on power that is classed as a problem? |
Because code reading or a service won't cure this problem
Either the battery is on its last legs, or you've had the engine off and been listening to music.
Posted: Thu Jan 27, 2011 10:08 am |
lee its probably a case of both of the above lol
Posted: Thu Jan 27, 2011 10:09 am |
Fixed my problem, but then there were a couple of other things wrong with mine when I got the eco mode message
Posted: Thu Jan 27, 2011 10:10 am |
CD-vRS wrote: |
Jay794 wrote: |
Incorrect.
THIS
| No longer a 206 owner
Astra H sxi. 1.7Cdti | |
