Latest: sparrowdclxvi
Overall: 17139
Online Now [519]:
Visitors: 519
Today: 94434
Total: 112778339
Forums › The Car › 206 Problems › 206 drinking petrol and it only a 1.1 plz help
porkie
PostPosted: Thu Jan 27, 2011 2:57 pm Up
please take 2 mins to read this story iam pulling my hair out with my 206
right then my 206 has been bad on petrol for a while i had a new manifold/cat fitted 20/12/2010 due to old one braking week after new middle pipe and back box all cheap parts not gen pug parts as the cost a bomb 2 week after then car was serviced still no change on the amont of fuel it was using shortly after engine management light came on when to have code read and it said CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD (BANK 1) code no p0420 the bloke in the garage said it was because it was a cheap cat and it needs replacing i then went to a pug specialist told him my story he said same cheap cat doesnt last long when i said its been on 4 weeks he said he has one car in that had one fitted 2 weeks ago and it was no good.i know the are two sensors one before cat and one after cat they both gave readings on the diagnostic machine but could these be the problem instead of cat.even thought both garages said its the cat the thing i carnt work out is that when new cat was fitted there was no change in the amount of petrol the car was using still same could the sensors be my problem
please help me my car is doing 120 miles to £30
any help is greatfull
thanks
show me the 206 trix
Dabamash
PostPosted: Thu Jan 27, 2011 3:00 pm Up
Staff - Daba
My 1.1 does 300 to £45 at the moment, 250 if I push it. Something's not right with yours.
Unless you're just driving like a crazy fool Wink
porkie
PostPosted: Thu Jan 27, 2011 3:05 pm Up
dont drive to crazy mate carnt get my head round what it is you now anyone on here that could maybe shed some light on the problem
Dabamash
PostPosted: Thu Jan 27, 2011 3:07 pm Up
Staff - Daba
Plenty of people on here will shed some light on it when they find the thread.
I would suggest a faulty sensor, but it doesn't match the poor fuel consumption.
porkie
PostPosted: Thu Jan 27, 2011 3:09 pm Up
so a faulty sensor wouldnt affect the fuel being used
stevedude
PostPosted: Thu Jan 27, 2011 3:11 pm Up
ya get a years warrenty on the cat, so go back and make em give ya a new one
Happydays
Dabamash
PostPosted: Thu Jan 27, 2011 3:12 pm Up
Staff - Daba
Not sure. I don't think the sensors have any influence on the fuel system. I'm useless when it comes to engines though, I know how they work, but that's about it.
PostPosted: Thu Jan 27, 2011 3:15 pm Up
You're seem to be referring to the lambda sensors. My knowledge is not the best in this area but I know it takes the readings and I think if its dodgy it could cause your car to overfuel in which case could be using more fuel?
Dabamash
PostPosted: Thu Jan 27, 2011 3:17 pm Up
Staff - Daba
Yeah, lambdas. If the sensor is connected to the fuel system, then that's a good possibility.
Get it fault read and see if they can be a bit more specific.
Spanerman
PostPosted: Thu Jan 27, 2011 3:18 pm Up
Yep, pretty much all the sensors on the engine are there to controll fuel/spark Wink
Lambder, temp or map would cause the fueling to be off
Sam
Hello
porkie
PostPosted: Thu Jan 27, 2011 3:23 pm Up
when it was on code reader would it of came up that the sensors were faulty or dont they show up if they are dodgey
the code reader said this when i took the car
Dabamash
PostPosted: Thu Jan 27, 2011 3:26 pm Up
Staff - Daba
Downstream lambda probably needs replacing. Same happened to my 1.1.
Don't quote me on that though
porkie
PostPosted: Thu Jan 27, 2011 3:28 pm Up
i have found a 1.4 breaking near me will sensors from a 206 1.4 fit my 206 1.1
Dabamash
PostPosted: Thu Jan 27, 2011 3:29 pm Up
Staff - Daba
Probably. I got mine replaced under warranty, so no idea what it costs new.
PostPosted: Thu Jan 27, 2011 3:30 pm Up
Mate, £30 to 120miles aint bad
I will get about 80 to 100 proper eco driving (change at 2k) on £15, so it could be the way you drive Wink
