Posted: Thu Jan 27, 2011 3:50 pm |
Hi all, 2nd problem or not as the case may be but only having had the 206 for a few days thought i would ask!! The temp gauge only reaches roughly 80 degrees and doesn't rise any further, now on other cars its normally 90 ish is 80 correct for my pug??
got a couple of other jobs needing doing so may aswell do em at the same time!!
steve
| If in doubt, drop a cog and put your foot down  | |
Yes for a Hdi 80 is normal no need to worry
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Thu Jan 27, 2011 3:51 pm |
Car should be fine the temp doesnt go really high on the HDi not unles you cane it or sit intraffic for a long time
Posted: Thu Jan 27, 2011 3:52 pm |
nice one danny, cheers for that
Posted: Thu Jan 27, 2011 3:53 pm |
spot on, chuffed to hear it!! busy day tommorow sorting brakes and suspension parts didn't more work to add to the list!!
Posted: Thu Jan 27, 2011 4:36 pm |
as mikey said they dont really run hot at all and somtimes take ages for the fan to kick in
Posted: Thu Jan 27, 2011 4:39 pm |
normal, because fan kicks in at 80
Posted: Thu Jan 27, 2011 4:40 pm |
Mine hovers about 70 most of the time
Posted: Thu Jan 27, 2011 5:40 pm |
just a quickie then, when does the ECU see the engine as being warm?
like when a petrol does, if it doesn't and the stat sticks open it runs rich
do these engines behave the same?
i would assume once cold start is finished it wouldn't matter so much but just wondered if my MPG goes abit south
