Latest: Wan1977
Overall: 17118
Online Now [36]:
Visitors: 35
Today: 43080
Total: 95633693
Forums › Tuning, Modification & Legal › Project Cars › Johnk progress thread
johnk
PostPosted: Tue Jun 29, 2010 9:31 am Up
not really many updates apart from had the car in for an mot, falied on the following:
*brake pedal creeps down under servo assistance and touches floor. (changed for a bigger servo, still doing same hmm)
*powersteering pipe leaking from a seal. (got seals from peugeot just need to change them)
*both front tryes fouling inner arch on full lock.
*both front wheelbearing excessive play. (now fixed)
also changed my stadard dash clock and wired in a ppt40 and got the grey dash console for the wider clock
Old info post count 1500
EuroPeugeot
PostPosted: Tue Jun 29, 2010 10:35 am Up
Keep it coming buddy, looking good!
jase123
PostPosted: Tue Jun 29, 2010 12:24 pm Up
looking good mate
Signature removed due to size
Lecktorious
PostPosted: Wed Jun 30, 2010 6:28 am Up
Trade Rating: +59
Whats making the tyres catch on full lock, are they the wrong profile? Are you still using the 1.4 TU master cylinder? If you are, you'll be needing one from a 206 GTi or a 306 GTi-6 / 406 V6. Not sure how the latter will fit though...
'98 Nile Blue 306 GTi 6
johnk
PostPosted: Wed Jun 30, 2010 8:57 am Up
not really sure mate, could just be as the coilovers are wound right down i bought spacers but need longer bolts to fit them.
yeah still using the 1.4 master cylinder changed to a bigger servo, would i have to get the master cylinder from one without abs same as mine?
Lecktorious
PostPosted: Wed Jun 30, 2010 3:37 pm Up
Trade Rating: +59
You'll defo need to swap the master cylinder mate, that's what's causing the massive amount of pedal travel. Nore sure about the ABS though, as you've not got ABS it might start throwing up all sorts of ABS error codes though when the ECU senses the ABS pump isn't present Confused
johnk
PostPosted: Wed Jun 30, 2010 6:47 pm Up
cheers for the heads up will pop to burnside over the weekend have a look Thumb Up
Lecktorious
PostPosted: Tue Aug 03, 2010 4:45 pm Up
Trade Rating: +59
Updates? Very Happy
Danny.
PostPosted: Wed Aug 04, 2010 3:58 pm Up
Looking good mate. Especially the engine swap Wink Just a quick question? What do you tell the insurence company GTI or LX?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
johnk
PostPosted: Sun Aug 15, 2010 8:32 am Up
G. wrote:
Updates? Very Happy
Had it in for another mot today also got an engine flush and oil change, failed on emisions and brake load valve i think it was so nothing big, driving it home to fix the things and about half a mile from home there's a strong smell of petrol(thought nothing of it as its been overfueling with petrol coming out exhaust), got home on the drive and the smell was so strong was unreal, Looked under the car to see petrol spewing out all over the hot exhaust and petrol in the car park where i had driven!.
At this point told my mum to move her car and asked if anyone had a fire extinguisher as i was sure it was going up in flames!.
Cars still hot so not checked to see what went wrong yet luckily took a long way home from garage and avoided 5 speedbumps my exhaust had scraped over on the way for the mot or could have sparked and went boom!.
johnk
PostPosted: Sun Aug 15, 2010 8:46 am Up
Things it failed on were.
1.exhaust emissions lambda reading after 2nd fast idle outside specified limits[7.3.D.2b]
2.Brake load sensing valve linkage seized[3.6.E.4]
Anony-X
PostPosted: Sun Aug 15, 2010 10:59 am Up
1. i threw some redex cleaner through my car before the MOT, like 5x what they recommended than bombed it up and down a dualie to get the cat nice and hot and run the redex through and mine passed after failing on 2nd fast idle emissions
2. WD40 to the seized valve on the rear axe
Upgrade - Toyota Corolla 190BHP TSport
RIP 206 and Corolla Sad
johnk
PostPosted: Sun Aug 15, 2010 11:12 am Up
Nice one mate, will give it a try!
The emissions sheet:
Fast Idle Test Max
Engine Speed = ---Rpm not checked 1950-3050
CO Level = 0.12% Pass 0.30
HC Level = 24ppm Pass 200
Lambda = 1.07 Fail 1.03
Second Fast Idle Test Max
CO Level = 0.09% Pass 0.30
HC Level = 11ppm Pass 200
Lambda = 1.23 Fail 1.03
Natural Idle Test Max
Engine Speed = ---Rpm Not checked 550-850
CO Level = 0.15 Pass 0.50
sniper1
PostPosted: Sun Aug 15, 2010 2:32 pm Up
john k, nice build thread mate.
quick one...what did you do with your showcage??
johnk
PostPosted: Sun Aug 15, 2010 3:02 pm Up
Cheers, erm sold it last year to jaymartell off here think it was.
Page 3 of 5
