Forums › The Car › 206 Problems › clutch touching steering column? |
Posted: Sun Jan 30, 2011 8:36 am |
When the clutch it down, I have noticed I can feel the steering wheel column move if I am turning the steering wheel at the same time. Is this normal?
It feels as though there should be carpet stopping the clutch meeting the column? Am I pressing the clutch down too far?
It feels like it is grinding away at the pedal or my shoe! lol
Posted: Sun Jan 30, 2011 8:37 am |
Its normal, I can feel the steering column turning to if i'm wearing my work boots.
Posted: Sun Jan 30, 2011 8:39 am |
lol i cant feel anything past the engine rattle, its sounds like a london taxi
Posted: Sun Jan 30, 2011 10:59 am |
I've done this once in my 206. Just get some smaller feet.
