Online Now [1011]:
Visitors: 1011
Today: 243177
Total: 152632580
Forums › The Car › 206 Problems › Is My Fuel Filter Blocked?
rob_1990
PostPosted: Sat Jan 29, 2011 8:41 am Up
Hello all, You may have seen my post the other week about my 180 problems. I am still having problems and i am starting to think it might be down to the fuel filter.
The car is starting to run a bit lumpy and ideling is eratic. Sometimes when i accelerate it hesitates. It all started whilst running on Tesco Momentum and since then i have tried different types i.e shell v-power.
I think the car still has the original fuel filter and has now done 62,000 miles.
I originally thought that either a piston ring is worn or the head gasket is on its way out but i removed the plugs again today and checked for oil etc, they all seem fine.
Does anyone else think this may be the problem? has anyone else experienced anything like this
Cheers
PostPosted: Sat Jan 29, 2011 8:42 am Up
One way to surely find out. Won't take long to replace, Wink
Ash
PostPosted: Sat Jan 29, 2011 8:50 am Up
Yup... as above. And give it a full service.
stevedude
PostPosted: Sat Jan 29, 2011 9:15 am Up
and its cheap to do lol
Happydays
NICKST
PostPosted: Sat Jan 29, 2011 9:36 am Up
180 fuel filter are in the tank and don't normally ever need changeing. Try cleaning your map sensor and make sure it hasnt got ngk plugs isn't it as the pugs don't like them. I also use tesco momentum fuel as my car seem to like it.
rob_1990
PostPosted: Sat Jan 29, 2011 9:39 am Up
Wheres the map sensor? Is the fuel filter still easy to change?
NICKST
PostPosted: Sat Jan 29, 2011 9:46 am Up
Never attempted the fuel filter as peugeot told me it will never need changing. The map sensor is under the throttle body held in by one bolt clean the throttle body while your there.
rob_1990
PostPosted: Sat Jan 29, 2011 9:52 am Up
Ok mate cheers. Do i get to it from above or below? shall i clean it with anything special?
NICKST
PostPosted: Sat Jan 29, 2011 10:02 am Up
Take the airbox out will make it easier to get to. Clean with electrical cleaner mate
rob_1990
PostPosted: Sat Jan 29, 2011 10:10 am Up
Sorry if i seem an idiot. Any pointers as of what it looks like? colour? cheers dude
MFACTOR001
PostPosted: Sat Jan 29, 2011 10:58 am Up
possibly the filter certantly worth a try very low cost and it shore wouldent hurt to have a new one.
MFACTOR RAP1D HDI
TEAM: NO BASE JUST RAW ENGINE
Tools are cheap experiance is invaluable
I make no appolagies for spelling punctuation
NICKST
PostPosted: Sat Jan 29, 2011 11:11 am Up
Will look like this www.google.co.uk/m/sea...sensor#i=6
rob_1990
PostPosted: Fri Feb 04, 2011 8:03 am Up
All fixed... Turned out to be a faulty temperature sensor. It's been replaced, fault codes cleared and all is well!
