Latest: tc.206
Overall: 17147
Online Now [150]:
Visitors: 150
Today: 10915
Total: 116553388
Forums › The Car › 206 Problems › Alloy wheel stuck on hub
Andrew
PostPosted: Sat Jan 29, 2011 11:30 am Up
Went to take my front wheel off today, loosened the bolts jacked it up and taken the bolts out no problem. Neither me, my dad or the guy from next door could pull the wheel off, tried tapping it to no avail
The garage who put my alloys on obviously didnt you copper grease. What can I do to loosen the wheel off? I've put WD40 in the centre hole of the wheel hoping it might help overnight for when i try again tomorrow
My 206 thread
www.detailedbyandrew.com
PostPosted: Sat Jan 29, 2011 11:42 am Up
do you suppose to put copper grease on?
chunkielad
PostPosted: Sat Jan 29, 2011 11:44 am Up
Lie on the floor and give the right hand edge of the wheel an almighty boot with your size 10s! It's the only way to break the seal if tapping hasn't sorted it - never put copper grease before fitting a wheel and never had an issue myself unless the bolts have been over tightened by a garage etc.
If you do not try you will NEVER succeed!
Salty_jon
PostPosted: Sat Jan 29, 2011 11:45 am Up
Put a piece of wood on the back of the wheel and tap the wood with a hammer. Turn it and tap again. Or put on bolt in a couple of threads, get under the car and kick it off. Make sure u clean it up and copper slip before you refit it.
206 sold but can\'t wait to get another. Swaps for a Leon Cupra anyone?
PostPosted: Sat Jan 29, 2011 11:47 am Up
Lead hammer FTW, doesn't damage the alloy as you smack it off.
Making a lead hammer is also the perfect way to use up all those old lead wheel weights you cant fit on customers cars anymore Laughing
paulrushton
PostPosted: Sat Jan 29, 2011 11:49 am Up
Another way if all else fails is to loosen the wheelnuts and then go round the block. That's what an RAC man told me if everything else fails. Normally though a good whack with a rubber mallet frees them off.
Peugeot 206 GTI HDI Black
Andrew
PostPosted: Sat Jan 29, 2011 11:52 am Up
Thanks for the replies guys
I want to get the problem sorted incase I get a puncture
Im trying again tomorrow, we even tried lowering the jack and not even the weight of the car did anything, we tried the wood and hammer trick
Am I wasting my time with WD40 in the hole?
My 206 thread
Lecktorious
PostPosted: Sat Jan 29, 2011 12:02 pm Up
Trade Rating: +59
You're not using enough force Wink
Rotate the wheel, tapping the back as it spins and then hit it hard.
'98 Nile Blue 306 GTi 6
DeadEyePaul
PostPosted: Sat Jan 29, 2011 12:25 pm Up
Loosen it a bit, reverse back and forth a couple of times. Jack it back up and give it a good strong kick
PostPosted: Sat Jan 29, 2011 12:26 pm Up
Rubber mallet.
-RAJ-
PostPosted: Sat Jan 29, 2011 12:32 pm Up
just done this to mine, used a bit of wood and a hammer
PostPosted: Sat Jan 29, 2011 1:35 pm Up
Man up or go to the gym
PostPosted: Sat Jan 29, 2011 1:37 pm Up
or keep kicking the wheel with your foot lol Laughing
Ash
He's asking about how to remove a wheel, not your life plans.
Andrew
PostPosted: Sat Jan 29, 2011 1:51 pm Up
Laughing
We werent knocking it too hard as we didnt want to knock the car off the jack, won't spare no horses tomorrow though just for you lee Wink
My 206 thread
