Latest: dreyfalon
Overall: 17121
Online Now [556]:
Visitors: 555
Today: 114245
Total: 97640498
Forums › The Car › 206 Problems › Drivers side washer jet (mot fail)
MrBombHead
PostPosted: Sat Jan 29, 2011 4:37 pm Up
Apart from my lights failures, I was also failed on the drivers sider washer "providing insufficient washer liquid" and by insufficient, it meant NONE!
I've searched the forum but only found info about new jets or the differences between them the phases)
I've used a needle to try clear it out (as I used to on my fiesta) but to no avail.
I opened the bonnet and saw the pipes are hidden by the fabric.
So my question is...
Is there something known that causes this...
How do I get the damn fabric off
And lastely, any ideas???
Bombhead
My 206 - 206info.co.uk/Forums/v...23351.html
Facebook - www.facebook.com/Bombhead
PostPosted: Sat Jan 29, 2011 4:46 pm Up
Just take off the mushroom clips then the sound deadening will come away.
New washer jets are about £8 from Peugeot
Might as well upgrade to Phase two ones if you dont already have them, they spray a mist and it doesn't look like you have two erect nipples on your bonnet.
stuy180
PostPosted: Sat Jan 29, 2011 4:48 pm Up
The fabric is only held in with butterfly type clips, use a small flat head screwdriver to pop the centre of the clips out then the rest will follow.
Apart from unblocking with a pin like you have mentioned, it could be the pipe that is blocked or come away from the jet itself although I would think you would notice water somewhere in or under the engine bay.
If you can't see anything obvious, I would source a new jet from a scrappy to try, they are very easy to remove too.
Good luck Very Happy
MrBombHead
PostPosted: Sat Jan 29, 2011 5:00 pm Up
Thanks for the speedy replies guys (this forum actually rocks btw!!!)
I will get under the fabric tomorrow and unplug the pipe from the jet and see if any water comes out. If it does then its almost certainly the jet itself.
I think I may need to get a break light switch from Peugeot anyway (cannot seem to find them online).
Thanks again guys.
Bombhead
giveitsomebar
PostPosted: Sat Jan 29, 2011 5:26 pm Up
when you unplug the pipe try and get use of an airline and blow it down the pipe that should clear any blockage
perry081064
PostPosted: Sun Jan 30, 2011 8:30 am Up
did this the other day ... get the phase 2 jets, much better Wink
206 2.0 HDI
bertt
PostPosted: Sun Jan 30, 2011 8:51 am Up
anybody have a link for the phase to jets of ebay or something I oculd do with upgrading mine
PostPosted: Sun Jan 30, 2011 8:55 am Up
There normally cheaper from a Peugeot main dealer Wink
bertt
PostPosted: Sun Jan 30, 2011 9:47 am Up
anybody got a part number. . .(awaits lee to post it Razz )
PostPosted: Sun Jan 30, 2011 10:32 am Up
Part Number 6438 AV @ £5.57 each
bertt
PostPosted: Sun Jan 30, 2011 12:27 pm Up
never fail mate haha chears
MrBombHead
PostPosted: Tue Feb 01, 2011 1:39 pm Up
It would appear that under the noise fabric that the pipe that splits off to the drivers side was twisted and just needed to be twisted back and all the pipe tidyed up.
This can be closed. Thanks a lot for your help guys. Only my break lights to fix now then its MOT is sorted
Bombhead
leon206
PostPosted: Tue Feb 01, 2011 1:51 pm Up
huh interesting. pipes dont twist themselves. anyone been under your bonnet lately?
peugeot
MrBombHead
PostPosted: Tue Feb 01, 2011 2:18 pm Up
Na only me, and I've dont nothing but top her up with water.
Tis strange, but then again, its been like that since the day I bought it. So could have happened before.
Bombhead
