Posted: Sun Jan 30, 2011 9:03 am |
As title really - the right side repeater is flashing about twice as fast as it should. The left side repeater is working fine as are all the other electronics in the car. It's an 05 1.4 sport.
I recently changed the headunit, but it only occured about the second time I used the car after doing that. I've done a BSi soft reboot, but that didn't solve it.
Any help would be greatly appreciated.
Posted: Sun Jan 30, 2011 9:07 am |
that usually happens when a bulb has gone
have you checked the bulbs ?
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Sun Jan 30, 2011 9:10 am |
as above!
Posted: Sun Jan 30, 2011 9:19 am |
Trade Rating: +32
a blown bulb somewhere in the indication systemm has blown.
put your hazards on and have a walk around the car
Posted: Sun Jan 30, 2011 9:23 am |
or the connection could have come loose mine did this after putting new lights in once and i found i had not put the connector in fully so check the connections for them
Posted: Sun Jan 30, 2011 9:44 am |
Spot on - it was the rear right hand bulb! Thanks!
So is this supposed to happen so that you know when a bulb has gone?
I looked for a 'how to' for taking out the rear light to change it, but couldnt find one. Can anyone point me in the right direction?
Posted: Sun Jan 30, 2011 9:45 am |
| adzar wrote: |
Yes, cars have been doing that since before you where born
Posted: Sun Jan 30, 2011 9:49 am |
Trade Rating: +32
| adzar wrote: |
I looked for a 'how to' for taking out the rear light to change it, but couldnt find one. Can anyone point me in the right direction? |
open boot, look right, pull side carpet back. should see a black plastic wing nut type thing. unscrew it. pull light forward slowly untill you see the plug. locate the tab, push the tab in while pulling the whole plug out
Posted: Sun Jan 30, 2011 9:51 am |
there used to be a how to... on this must of been moved ,
as above is easy.
Posted: Sun Jan 30, 2011 9:59 am |
Thanks for all the help!
Posted: Fri Feb 11, 2011 11:27 am |
Peugeot and halfrauds both told me I needed an amber bulb, but my car needed the clear bulb with the knobs at opposite sides.
Weird.
Posted: Fri Feb 11, 2011 11:34 am |
Both amber and clear would have worked.
Posted: Sat Feb 12, 2011 10:41 am |
| Lee wrote: |
| Both amber and clear would have worked. |
No the amber didn't fit, because the two little knobs are in the wrong place. They had to be at opposite sides as they are on the clear bulb.
Posted: Sat Feb 12, 2011 10:44 am |
| adzar wrote: |
| Lee wrote: |
No the amber didn't fit, because the two little knobs are in the wrong place. They had to be at opposite sides as they are on the clear bulb. |
You can get amber bulbs in different fitments if you know where to look
Posted: Thu Nov 20, 2014 1:26 pm |
HI guys I hope someone here can help. my wife drives a 206hdi which had a rear indicator out, I replaced the bulb and all bulbs are now working fine however the left side of the car flashes twice as quickly as the right..Yes I know it only flashes quickly if the current is out by a faulty bulb/ bad connection, however I have checked all connections and as the bulbs are all working I'm stumped..... Hoping you can help???? Thanks in advance...
