Posted: Sun Jan 30, 2011 9:18 am |
not being thick but does a hdi have an idle control valve? because my needle on the rev counter moves up and down slightly when in netural and i have noticed that it goes up quickly for a second then comes back down
Posted: Sun Jan 30, 2011 9:35 am |
No, its ECU controlled.
The idle will flutter if things such as the AC is on.
Posted: Sun Jan 30, 2011 9:40 am |
I'd check the stepper motor mate.
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Sun Jan 30, 2011 9:43 am |
elcamino wrote: |
I'd check the stepper motor mate. |
Doesn't have one.
Posted: Sun Jan 30, 2011 9:45 am |
no ac on, i put some redex in the diesel didnt make any difference
Posted: Sun Jan 30, 2011 9:48 am |
Shouldn't use redex, as once you use it, you need to keep using it. Should use premium fuel instead.
How much does it flutter up and down?
You recently had the battery off?
Posted: Sun Jan 30, 2011 10:03 am |
it almost sounds like its purring lol battery not been off
Posted: Sun Jan 30, 2011 10:04 am |
Lee wrote: |
You recently had the battery off? |
Just out of curiosity, why???
Ben.M
| "Being second is to be the first of the ones who lose. " Ayrton Senna | |
Posted: Sun Jan 30, 2011 10:23 am |
Lee wrote: |
elcamino wrote: |
Doesn't have one. | Sorry thought it does..
