Latest: tbafonso
Overall: 17130
Online Now [55]:
Visitors: 54
Today: 3368
Total: 104153411
Forums › The Car › 206 Problems › could anyone help me locate the fan wiring relay?
robdob
PostPosted: Tue Feb 01, 2011 12:55 pm Up
i need help finding the fan wiring relay as i think it needs replacing... anyone know where it is and how i go about replacing it?? help?
PostPosted: Tue Feb 01, 2011 1:38 pm Up
It right at the front of the car behind the grille. It's behind a removable panel.
You can see the panel here to the left of the fan.
